Date/Time: Thu, 16 Jan 2025 00:42:18 +0000
Exchange fees
View Count: 971
[2017-10-05 10:54:06] |
User554217 - Posts: 2 |
Dear Sierra Chart Support, Do I have to pay extra for Eurex and CBOT data if I am already paying for this live feed through my broker and TT X Trader (desktop) platform? Regards, Howard |
[2017-10-05 17:20:49] |
TT X Trader is not a supported trading platform service. They are all listed here: http://www.sierrachart.com/index.php?page=doc/SupportedDataAndTradingServices.php So the answer to the question would be yes in your case. Not only that, but you would also have to pay the higher priced CBOT exchange fee. This is explained here: http://www.sierrachart.com/index.php?page=doc/FuturesData.php So we would recommend using a trading platform service instead like CQG which is supported. Sierra Chart also fully supports trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-05 17:22:45
[2017-10-05 17:22:19] |
The prior post has been updated.
