Date/Time: Thu, 16 Jan 2025 03:15:30 +0000
Time & Sales Combine Record Function
View Count: 1239
[2017-10-05 05:11:55]
User379884 - Posts: 45
Would it be possible to consider having the fixed 1 second combine record function to be user adjusted and defined with the ability to go down to a decisecond or millisecond?
For example, I could define that records received in 50 millisecond increments be combined by bid and ask.
If not possible that's ok. It would be a great little feature if it could though.
Thanks.
[2017-10-09 19:09:21]
This is not possible.
But if you use the Sierra Chart Exchange Data Feed it is possible to combine the trades into the original summary trade. This is supported for the CME.
Although this combining is only done within the chart at this time and not the Time and Sales window.
Refer to:
