Date/Time: Thu, 16 Jan 2025 02:52:36 +0000
Spreadsheet Study Issue
View Count: 670
[2017-10-05 00:07:09] |
Tom Hanks - Posts: 20 |
Hello, I would like to to have trade exit logic based on particular indicator values at the time the trade was entered. The price of last entry is saved to use for this kind of logic but I would like to have some other cells that can record what the values of certain indicators were at the time of trade entry. For example, I can say I want my stop to be the last entry fill price ($J$48) minus .001 or something, but how would I make a stop that triggers if price goes .001 lower than the lower 2nd standard deviation at the time of entry? Basically I need cells that will record a temporary value (like J48) of my choosing that will be available as long as I am in a trade. Is this something that can currently be done with the spreadsheet system? If not, is it possible this may be added. Thanks!! |
[2017-10-10 17:13:37] |
In general for something like this you really should be using ACSIL: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
