Date/Time: Thu, 16 Jan 2025 07:55:08 +0000
[Locked] - my activation
View Count: 4404
[2017-10-12 16:08:11]
User798034 - Posts: 41
I mapped live account to sierra.
Stil sim mode. how can I fixed ? Please see attached,
I followed https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SetupInstructions and http://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php
I cannot switch from sim to my E..
imagee3.png / V - Attached On 2017-10-12 16:08:00 UTC - Size: 84.23 KB - 378 views
[2017-10-12 17:12:52]
In the list box at the top of the Trade Activity Log that contains the list of Symbols, select the symbol without [Sim] in front of it. Refer to:
Trade Activity Log: Viewing Historical Trade Activity
[2017-10-16 13:56:11]
User990042 - Posts: 5
still not working. see attachment
imagee4.png / V - Attached On 2017-10-16 13:56:05 UTC - Size: 32.77 KB - 330 views
[2017-10-16 13:58:53]
File attached
imagee5.png / V - Attached On 2017-10-16 13:58:44 UTC - Size: 93.33 KB - 312 views
[2017-10-16 14:17:11]
live account mapped. but positions not opened. only sim nonstop
[2017-10-16 18:49:46]
In regards to the Trade Activity Log tabs, they depend upon order fills to generate the information. Refer to:
Trade Activity Log: Missing Order Fills from Trade Activity Log
Refer to this section here about this:
Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes
Date Time Of Last Edit: 2017-10-16 18:50:34
[2017-10-20 19:49:00]
Many thanks for answers and support. Much appreciated.
Last question I hope is : how can i open to chart attached DOM screenshot with Limit orders.
imagee6.png / V - Attached On 2017-10-20 19:48:49 UTC - Size: 36.32 KB - 328 views
[2017-10-21 20:15:59]
Do I need to have activated this if I want to see Limit orders on DOM?
And if yes should I switch data trade services to sierra or stil lease my settings as:
SP 5 data siera purchased and data from Gain cap.
imagee8.png / V - Attached On 2017-10-21 20:14:51 UTC - Size: 14.86 KB - 293 views
[2017-10-21 20:16:21]
I can attach dom to chart but i dont see a limit orders.
[2017-10-22 00:00:18]
In response to post #31 and #32, refer to the instructions here:
Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns
You need to contact your broker and make sure your Gain Capital account is authorized for CME market depth data.
[2017-10-22 15:34:26]
Gain cap saying its authorised for depth data.
Are you sure i dont need to activate attached service?
imagee8.png / V - Attached On 2017-10-22 15:34:14 UTC - Size: 14.86 KB - 325 views
[2017-10-22 15:40:43]
i still see this.
(screenshot was created when market was opened.)
imagee9.png / V - Attached On 2017-10-22 15:40:19 UTC - Size: 4.63 KB - 309 views
[2017-10-23 01:42:27]
What is the symbol of the Trading DOM?
You need to follow the instructions here to add the Bid Size and Ask Size columns if they are not already added:
[2017-10-23 07:22:56]
symbol is NQ
they are added. see screenshot.
imagee11.png / V - Attached On 2017-10-23 07:22:23 UTC - Size: 28.95 KB - 306 views
[2017-10-23 08:11:02]
GOT IT. TANKS~
[2017-10-23 08:54:55]
Go to that NQ chart with the Chart DOM which does not have any market depth quantities displayed, and select Chart >> Open Market Depth Window. Do you see the market depth data displayed now?
[2017-10-23 09:39:55]
Yes. All is ok now. Many thanks
[2017-10-23 09:40:37]
one more question. is there any keyboard shortcut to switch between chartbooks ?
[2017-10-23 17:19:21]
You can switch between Chartbooks through the CB menu or use these Control Bar buttons:
Control Bar: Control Bar Chartbook Buttons
[2017-10-24 20:40:25]
I cannot find IBM symbol.
what should i type in symbol field: IBM or NYSE IBM or what
[2017-10-24 20:54:38]
where i can find fibo retracement levels.
[2017-10-24 22:44:28]
We are now locking this thread. Those questions need to be posted in a separate Support Request and we will only provide support for a paid account. The account you are posting from is expired and will receive no support.
