Date/Time: Thu, 16 Jan 2025 01:13:56 +0000
mweston
View Count: 804
[2017-10-04 15:59:42] |
User239122 - Posts: 1 |
My charting is painting inacurate candles which makes it useless for trading . Have enclosed a sreenshot of a Gold 144tick chart which is painting wierd clusters of candles which is totally different when I compared it to the same chart from my broker .
Screen Shot 2017-10-04 at 11.16.08 PM.png / V - Attached On 2017-10-04 15:59:21 UTC - Size: 107.97 KB - 277 views Attachment Deleted. |
[2017-10-04 18:19:24] |
Refer to this section here about repeating bars: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: Repeating Bars with Number of Trades or Volume Bars And refer to step 12 here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
