Date/Time: Thu, 16 Jan 2025 01:07:32 +0000
SC not connecting
View Count: 744
[2017-10-04 14:15:15] |
User999501 - Posts: 2 |
Hello, My SC platform will not connect this morning. I have had AMP tech support helping but they don't have the answer. Can you help? |
[2017-10-04 16:59:34] |
Sierra Chart - Max - Posts: 5778 |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support |
[2017-10-04 17:39:08] |
You need to update to the latest version of Sierra Chart with Help >> Download Prerelease. Here are instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
