Date/Time: Sun, 24 Nov 2024 02:26:18 +0000
Difficulty login in
View Count: 1844
[2013-09-09 01:09:07] |
Yetlee - Posts: 12 |
IB , I inform you that I will be sending you a Message log. I cant kog in and my message log is advicing me to let it be reviewed thanks |
[2013-09-09 02:27:12] |
Assuming you are using the standalone desktop Interactive Brokers TWS, update it with this link: https://download2.interactivebrokers.com/download/tws40_upgrade_latest.exe Sierra Chart requires the newer versions of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
