Date/Time: Thu, 16 Jan 2025 00:44:30 +0000
Waiting to reconnect
View Count: 994
[2017-10-04 09:40:06]
User557464 - Posts: 5
GM,
I'm not able to connect sierra.
Please, see attached file!
The problem started after yesterday 5pm.
imageerror connection.jpg / V - Attached On 2017-10-04 09:38:42 UTC - Size: 352.57 KB - 319 views
[2017-10-04 09:45:19]
Provide a copy of the Message Log by following these instructions:
[2017-10-04 10:32:55]
Reading Internal Order ID file. | 2017-10-04 05:08:39
Reading Trade Orders file. | 2017-10-04 05:08:39
Reading Trade Positions file. | 2017-10-04 05:08:39
Listening on UDP port 22903. | 2017-10-04 05:08:39
Software version: 1558 | 2017-10-04 05:08:39
Uses New Spreadsheets | 2017-10-04 05:08:39
Usage end date: 2017-10-19 | 2017-10-04 05:08:39
Enabled for: Advanced Features. | 2017-10-04 05:08:39
Enabled for: Sierra Chart Historical Data Service. | 2017-10-04 05:08:39
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-10-04 05:08:39
Current selected Data/Trading service: Rithmic Trading | 2017-10-04 05:08:39
Chart Update Interval: 500 | 2017-10-04 05:08:39
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-10-04 05:08:39
2017-10-04 04:08:43 Local computer time | 2017-10-04 05:08:39
2017-10-04 09:08:43 Local computer time in UTC | 2017-10-04 05:08:39
2017-10-04 05:08:43 Local computer time in SC Time Zone | 2017-10-04 05:08:39
2017-10-04 09:08:41 Server time in UTC | 2017-10-04 05:08:39
Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-10-04 05:08:39
Program path: C:\SierraChart\ | 2017-10-04 05:08:39
Data Files path: C:\SierraChart\Data\ | 2017-10-04 05:08:39
OS Version Number: 6.2 | 2017-10-04 05:08:39
Locale Setting: C | 2017-10-04 05:08:39
Checking for new symbol settings for service code rim | 2017-10-04 05:08:39
HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-10-04 05:08:39
HTTPS connection to www.sierrachart.com:443 (3) | Connecting to IP: 204.15.192.108. | 2017-10-04 05:08:39
Symbol settings are up-to-date for rim | 2017-10-04 05:08:44
Rithmic Trading | Port for executable: 56237 | 2017-10-04 05:08:48
Listening socket (808), port 56237 | Closed. | 2017-10-04 05:08:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:08:48
HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2017-10-04 05:08:49
HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2017-10-04 05:08:49
HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-10-04 05:08:49
HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-04 05:08:49
HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-10-04 05:08:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56237 | 2017-10-04 05:08:50
DTC Client (4) | Creating socket. | 2017-10-04 05:08:50
DTC Client (4) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:08:50
Rithmic Trading | Connected to server. | 2017-10-04 05:08:50
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:08:50
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:08:50
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:08:50
Rithmic Trading | Sending logon request message. | 2017-10-04 05:08:50
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:08:50
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:08:50
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:08:50
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:08:52
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:08:52
Rithmic Trading | Received logon response. | 2017-10-04 05:08:52
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:08:52
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:08:52
Rithmic Trading | Logon error received from server | 2017-10-04 05:08:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:08:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:08:52
DTC Client (4) | Initiating close of socket by core. | 2017-10-04 05:08:52
Rithmic Trading | Disconnected. | 2017-10-04 05:08:52
DTC Client (4) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:08:52
DTC Client (4) | Socket gracefully closed by remote side. | 2017-10-04 05:08:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:08:52
DTC Client (4) | Closed. | 2017-10-04 05:08:52
Rithmic Trading | Port for executable: 56247 | 2017-10-04 05:08:54
Listening socket (888), port 56247 | Closed. | 2017-10-04 05:08:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:08:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56247 | 2017-10-04 05:08:56
DTC Client (5) | Creating socket. | 2017-10-04 05:08:56
DTC Client (5) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:08:56
DTC Client (5) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:08:57 *
DTC Client (5) | Initiating close of socket by core. | 2017-10-04 05:08:57
DTC Client (5) | Closed. | 2017-10-04 05:08:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:08:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:08:57
Rithmic Trading | Disconnected. | 2017-10-04 05:08:57
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:08:57
Rithmic Trading | Port for executable: 56249 | 2017-10-04 05:08:59
Listening socket (920), port 56249 | Closed. | 2017-10-04 05:08:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:08:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56249 | 2017-10-04 05:09:01
DTC Client (6) | Creating socket. | 2017-10-04 05:09:01
DTC Client (6) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:01
DTC Client (6) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:02 *
DTC Client (6) | Initiating close of socket by core. | 2017-10-04 05:09:02
DTC Client (6) | Closed. | 2017-10-04 05:09:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:02
Rithmic Trading | Disconnected. | 2017-10-04 05:09:02
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:02
Rithmic Trading | Port for executable: 56251 | 2017-10-04 05:09:04
Listening socket (876), port 56251 | Closed. | 2017-10-04 05:09:04
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56251 | 2017-10-04 05:09:06
DTC Client (7) | Creating socket. | 2017-10-04 05:09:06
DTC Client (7) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:06
DTC Client (7) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:07 *
DTC Client (7) | Initiating close of socket by core. | 2017-10-04 05:09:07
DTC Client (7) | Closed. | 2017-10-04 05:09:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:07
Rithmic Trading | Disconnected. | 2017-10-04 05:09:07
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:07
Rithmic Trading | Port for executable: 56253 | 2017-10-04 05:09:09
Listening socket (808), port 56253 | Closed. | 2017-10-04 05:09:09
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56253 | 2017-10-04 05:09:11
DTC Client (8) | Creating socket. | 2017-10-04 05:09:11
DTC Client (8) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:11
DTC Client (8) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:12 *
DTC Client (8) | Initiating close of socket by core. | 2017-10-04 05:09:12
DTC Client (8) | Closed. | 2017-10-04 05:09:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:12
Rithmic Trading | Disconnected. | 2017-10-04 05:09:12
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:12
Rithmic Trading | Port for executable: 56255 | 2017-10-04 05:09:14
Listening socket (920), port 56255 | Closed. | 2017-10-04 05:09:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56255 | 2017-10-04 05:09:16
DTC Client (9) | Creating socket. | 2017-10-04 05:09:16
DTC Client (9) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:16
Rithmic Trading | Connected to server. | 2017-10-04 05:09:16
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:09:16
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:09:16
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:09:16
Rithmic Trading | Sending logon request message. | 2017-10-04 05:09:16
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:09:16
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:09:16
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:09:16
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:09:17
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:09:17
Rithmic Trading | Received logon response. | 2017-10-04 05:09:17
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:09:17
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:09:17
Rithmic Trading | Logon error received from server | 2017-10-04 05:09:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:17
DTC Client (9) | Initiating close of socket by core. | 2017-10-04 05:09:17
Rithmic Trading | Disconnected. | 2017-10-04 05:09:17
DTC Client (9) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:09:17
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:17
DTC Client (9) | Socket gracefully closed by remote side. | 2017-10-04 05:09:17
DTC Client (9) | Closed. | 2017-10-04 05:09:17
Rithmic Trading | Port for executable: 56265 | 2017-10-04 05:09:19
Listening socket (888), port 56265 | Closed. | 2017-10-04 05:09:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56265 | 2017-10-04 05:09:21
DTC Client (10) | Creating socket. | 2017-10-04 05:09:21
DTC Client (10) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:21
DTC Client (10) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:22 *
DTC Client (10) | Initiating close of socket by core. | 2017-10-04 05:09:22
DTC Client (10) | Closed. | 2017-10-04 05:09:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:22
Rithmic Trading | Disconnected. | 2017-10-04 05:09:22
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:22
Rithmic Trading | Port for executable: 56267 | 2017-10-04 05:09:25
Listening socket (876), port 56267 | Closed. | 2017-10-04 05:09:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56267 | 2017-10-04 05:09:27
DTC Client (11) | Creating socket. | 2017-10-04 05:09:27
DTC Client (11) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:27
DTC Client (11) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:28 *
DTC Client (11) | Initiating close of socket by core. | 2017-10-04 05:09:28
DTC Client (11) | Closed. | 2017-10-04 05:09:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:28
Rithmic Trading | Disconnected. | 2017-10-04 05:09:28
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:28
Rithmic Trading | Port for executable: 56269 | 2017-10-04 05:09:30
Listening socket (888), port 56269 | Closed. | 2017-10-04 05:09:30
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56269 | 2017-10-04 05:09:32
DTC Client (12) | Creating socket. | 2017-10-04 05:09:32
DTC Client (12) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:32
DTC Client (12) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:33 *
DTC Client (12) | Initiating close of socket by core. | 2017-10-04 05:09:33
DTC Client (12) | Closed. | 2017-10-04 05:09:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:33
Rithmic Trading | Disconnected. | 2017-10-04 05:09:33
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:33
Rithmic Trading | Port for executable: 56272 | 2017-10-04 05:09:35
Listening socket (888), port 56272 | Closed. | 2017-10-04 05:09:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56272 | 2017-10-04 05:09:37
DTC Client (13) | Creating socket. | 2017-10-04 05:09:37
DTC Client (13) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:37
DTC Client (13) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:38 *
DTC Client (13) | Initiating close of socket by core. | 2017-10-04 05:09:38
DTC Client (13) | Closed. | 2017-10-04 05:09:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:38
Rithmic Trading | Disconnected. | 2017-10-04 05:09:38
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:38
Rithmic Trading | Port for executable: 56274 | 2017-10-04 05:09:40
Listening socket (524), port 56274 | Closed. | 2017-10-04 05:09:40
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56274 | 2017-10-04 05:09:42
DTC Client (14) | Creating socket. | 2017-10-04 05:09:42
DTC Client (14) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:42
Rithmic Trading | Connected to server. | 2017-10-04 05:09:42
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:09:42
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:09:42
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:09:42
Rithmic Trading | Sending logon request message. | 2017-10-04 05:09:42
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:09:42
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:09:42
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:09:42
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:09:43
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:09:43
Rithmic Trading | Received logon response. | 2017-10-04 05:09:43
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:09:43
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:09:43
Rithmic Trading | Logon error received from server | 2017-10-04 05:09:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:43
DTC Client (14) | Initiating close of socket by core. | 2017-10-04 05:09:43
DTC Client (14) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:09:43
DTC Client (14) | Socket gracefully closed by remote side. | 2017-10-04 05:09:43
Rithmic Trading | Disconnected. | 2017-10-04 05:09:43
DTC Client (14) | Closed. | 2017-10-04 05:09:43
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:43
Rithmic Trading | Port for executable: 56284 | 2017-10-04 05:09:45
Listening socket (828), port 56284 | Closed. | 2017-10-04 05:09:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56284 | 2017-10-04 05:09:47
DTC Client (15) | Creating socket. | 2017-10-04 05:09:47
DTC Client (15) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:47
DTC Client (15) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:48 *
DTC Client (15) | Initiating close of socket by core. | 2017-10-04 05:09:48
DTC Client (15) | Closed. | 2017-10-04 05:09:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:48
Rithmic Trading | Disconnected. | 2017-10-04 05:09:48
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:48
Rithmic Trading | Port for executable: 56286 | 2017-10-04 05:09:50
Listening socket (828), port 56286 | Closed. | 2017-10-04 05:09:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56286 | 2017-10-04 05:09:52
DTC Client (16) | Creating socket. | 2017-10-04 05:09:52
DTC Client (16) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:52
DTC Client (16) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:53 *
DTC Client (16) | Initiating close of socket by core. | 2017-10-04 05:09:53
DTC Client (16) | Closed. | 2017-10-04 05:09:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:53
Rithmic Trading | Disconnected. | 2017-10-04 05:09:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:53
Rithmic Trading | Port for executable: 56288 | 2017-10-04 05:09:55
Listening socket (400), port 56288 | Closed. | 2017-10-04 05:09:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:09:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56288 | 2017-10-04 05:09:57
DTC Client (17) | Creating socket. | 2017-10-04 05:09:57
DTC Client (17) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:09:57
DTC Client (17) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:09:58 *
DTC Client (17) | Initiating close of socket by core. | 2017-10-04 05:09:58
DTC Client (17) | Closed. | 2017-10-04 05:09:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:09:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:09:58
Rithmic Trading | Disconnected. | 2017-10-04 05:09:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:09:58
Rithmic Trading | Port for executable: 56290 | 2017-10-04 05:10:00
Listening socket (524), port 56290 | Closed. | 2017-10-04 05:10:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56290 | 2017-10-04 05:10:02
DTC Client (18) | Creating socket. | 2017-10-04 05:10:02
DTC Client (18) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:02
DTC Client (18) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:03 *
DTC Client (18) | Initiating close of socket by core. | 2017-10-04 05:10:03
DTC Client (18) | Closed. | 2017-10-04 05:10:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:03
Rithmic Trading | Disconnected. | 2017-10-04 05:10:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:03
Rithmic Trading | Port for executable: 56292 | 2017-10-04 05:10:05
Listening socket (828), port 56292 | Closed. | 2017-10-04 05:10:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56292 | 2017-10-04 05:10:07
DTC Client (19) | Creating socket. | 2017-10-04 05:10:07
DTC Client (19) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:07
Rithmic Trading | Connected to server. | 2017-10-04 05:10:07
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:10:07
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:10:07
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:10:07
Rithmic Trading | Sending logon request message. | 2017-10-04 05:10:07
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:10:07
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:10:07
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:10:07
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:10:09
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:10:09
Rithmic Trading | Received logon response. | 2017-10-04 05:10:09
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:10:09
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:10:09
Rithmic Trading | Logon error received from server | 2017-10-04 05:10:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:09
DTC Client (19) | Initiating close of socket by core. | 2017-10-04 05:10:09
DTC Client (19) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:10:09
DTC Client (19) | Socket gracefully closed by remote side. | 2017-10-04 05:10:09
Rithmic Trading | Disconnected. | 2017-10-04 05:10:09
DTC Client (19) | Closed. | 2017-10-04 05:10:09
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:09
Rithmic Trading | Port for executable: 56302 | 2017-10-04 05:10:11
Listening socket (632), port 56302 | Closed. | 2017-10-04 05:10:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56302 | 2017-10-04 05:10:13
DTC Client (20) | Creating socket. | 2017-10-04 05:10:13
DTC Client (20) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:13
DTC Client (20) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:14 *
DTC Client (20) | Initiating close of socket by core. | 2017-10-04 05:10:14
DTC Client (20) | Closed. | 2017-10-04 05:10:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:14
Rithmic Trading | Disconnected. | 2017-10-04 05:10:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:14
Rithmic Trading | Port for executable: 56304 | 2017-10-04 05:10:16
Listening socket (636), port 56304 | Closed. | 2017-10-04 05:10:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56304 | 2017-10-04 05:10:18
DTC Client (21) | Creating socket. | 2017-10-04 05:10:18
DTC Client (21) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:18
DTC Client (21) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:19 *
DTC Client (21) | Initiating close of socket by core. | 2017-10-04 05:10:19
DTC Client (21) | Closed. | 2017-10-04 05:10:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:19
Rithmic Trading | Disconnected. | 2017-10-04 05:10:19
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:19
Rithmic Trading | Port for executable: 56306 | 2017-10-04 05:10:21
Listening socket (636), port 56306 | Closed. | 2017-10-04 05:10:21
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:21
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56306 | 2017-10-04 05:10:23
DTC Client (22) | Creating socket. | 2017-10-04 05:10:23
DTC Client (22) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:23
DTC Client (22) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:24 *
DTC Client (22) | Initiating close of socket by core. | 2017-10-04 05:10:24
DTC Client (22) | Closed. | 2017-10-04 05:10:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:24
Rithmic Trading | Disconnected. | 2017-10-04 05:10:24
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:24
Rithmic Trading | Port for executable: 56308 | 2017-10-04 05:10:26
Listening socket (636), port 56308 | Closed. | 2017-10-04 05:10:26
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56308 | 2017-10-04 05:10:28
DTC Client (23) | Creating socket. | 2017-10-04 05:10:28
DTC Client (23) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:28
DTC Client (23) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:29 *
DTC Client (23) | Initiating close of socket by core. | 2017-10-04 05:10:29
DTC Client (23) | Closed. | 2017-10-04 05:10:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:29
Rithmic Trading | Disconnected. | 2017-10-04 05:10:29
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:29
Rithmic Trading | Port for executable: 56310 | 2017-10-04 05:10:31
Listening socket (992), port 56310 | Closed. | 2017-10-04 05:10:31
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:31
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56310 | 2017-10-04 05:10:33
DTC Client (24) | Creating socket. | 2017-10-04 05:10:33
DTC Client (24) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:33
Rithmic Trading | Connected to server. | 2017-10-04 05:10:33
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:10:33
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:10:33
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:10:33
Rithmic Trading | Sending logon request message. | 2017-10-04 05:10:33
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:10:33
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:10:33
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:10:33
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:10:34
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:10:35
Rithmic Trading | Received logon response. | 2017-10-04 05:10:35
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:10:35
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:10:35
Rithmic Trading | Logon error received from server | 2017-10-04 05:10:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:35
DTC Client (24) | Initiating close of socket by core. | 2017-10-04 05:10:35
DTC Client (24) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:10:35
DTC Client (24) | Socket gracefully closed by remote side. | 2017-10-04 05:10:35
Rithmic Trading | Disconnected. | 2017-10-04 05:10:35
DTC Client (24) | Closed. | 2017-10-04 05:10:35
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:35
Rithmic Trading | Port for executable: 56320 | 2017-10-04 05:10:37
Listening socket (600), port 56320 | Closed. | 2017-10-04 05:10:37
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:37
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56320 | 2017-10-04 05:10:39
DTC Client (25) | Creating socket. | 2017-10-04 05:10:39
DTC Client (25) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:39
DTC Client (25) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:40 *
DTC Client (25) | Initiating close of socket by core. | 2017-10-04 05:10:40
DTC Client (25) | Closed. | 2017-10-04 05:10:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:40
Rithmic Trading | Disconnected. | 2017-10-04 05:10:40
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:40
Rithmic Trading | Port for executable: 56322 | 2017-10-04 05:10:42
Listening socket (600), port 56322 | Closed. | 2017-10-04 05:10:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:42
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56322 | 2017-10-04 05:10:44
DTC Client (26) | Creating socket. | 2017-10-04 05:10:44
DTC Client (26) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:44
DTC Client (26) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:45 *
DTC Client (26) | Initiating close of socket by core. | 2017-10-04 05:10:45
DTC Client (26) | Closed. | 2017-10-04 05:10:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:45
Rithmic Trading | Disconnected. | 2017-10-04 05:10:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:45
Rithmic Trading | Port for executable: 56324 | 2017-10-04 05:10:47
Listening socket (876), port 56324 | Closed. | 2017-10-04 05:10:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:47
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56324 | 2017-10-04 05:10:49
DTC Client (27) | Creating socket. | 2017-10-04 05:10:49
DTC Client (27) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:49
DTC Client (27) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:50 *
DTC Client (27) | Initiating close of socket by core. | 2017-10-04 05:10:50
DTC Client (27) | Closed. | 2017-10-04 05:10:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:50
Rithmic Trading | Disconnected. | 2017-10-04 05:10:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:50
Rithmic Trading | Port for executable: 56326 | 2017-10-04 05:10:52
Listening socket (920), port 56326 | Closed. | 2017-10-04 05:10:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56326 | 2017-10-04 05:10:54
DTC Client (28) | Creating socket. | 2017-10-04 05:10:54
DTC Client (28) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:54
DTC Client (28) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:10:55 *
DTC Client (28) | Initiating close of socket by core. | 2017-10-04 05:10:55
DTC Client (28) | Closed. | 2017-10-04 05:10:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:10:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:10:55
Rithmic Trading | Disconnected. | 2017-10-04 05:10:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:10:55
Rithmic Trading | Port for executable: 56328 | 2017-10-04 05:10:57
Listening socket (600), port 56328 | Closed. | 2017-10-04 05:10:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:10:57
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56328 | 2017-10-04 05:10:59
DTC Client (29) | Creating socket. | 2017-10-04 05:10:59
DTC Client (29) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:10:59
Rithmic Trading | Connected to server. | 2017-10-04 05:10:59
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:10:59
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:10:59
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:10:59
Rithmic Trading | Sending logon request message. | 2017-10-04 05:10:59
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:10:59
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:10:59
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:10:59
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:11:00
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:11:00
Rithmic Trading | Received logon response. | 2017-10-04 05:11:00
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:11:00
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:11:00
Rithmic Trading | Logon error received from server | 2017-10-04 05:11:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:00
DTC Client (29) | Initiating close of socket by core. | 2017-10-04 05:11:00
DTC Client (29) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:11:00
DTC Client (29) | Socket gracefully closed by remote side. | 2017-10-04 05:11:00
Rithmic Trading | Disconnected. | 2017-10-04 05:11:00
DTC Client (29) | Closed. | 2017-10-04 05:11:00
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:00
Rithmic Trading | Port for executable: 56338 | 2017-10-04 05:11:02
Listening socket (632), port 56338 | Closed. | 2017-10-04 05:11:02
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:02
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56338 | 2017-10-04 05:11:04
DTC Client (30) | Creating socket. | 2017-10-04 05:11:04
DTC Client (30) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:04
DTC Client (30) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:05 *
DTC Client (30) | Initiating close of socket by core. | 2017-10-04 05:11:05
DTC Client (30) | Closed. | 2017-10-04 05:11:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:05
Rithmic Trading | Disconnected. | 2017-10-04 05:11:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:05
Rithmic Trading | Port for executable: 56340 | 2017-10-04 05:11:07
Listening socket (808), port 56340 | Closed. | 2017-10-04 05:11:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56340 | 2017-10-04 05:11:09
DTC Client (31) | Creating socket. | 2017-10-04 05:11:09
DTC Client (31) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:09
DTC Client (31) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:10 *
DTC Client (31) | Initiating close of socket by core. | 2017-10-04 05:11:10
DTC Client (31) | Closed. | 2017-10-04 05:11:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:10
Rithmic Trading | Disconnected. | 2017-10-04 05:11:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:10
Rithmic Trading | Port for executable: 56342 | 2017-10-04 05:11:12
Listening socket (808), port 56342 | Closed. | 2017-10-04 05:11:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56342 | 2017-10-04 05:11:14
DTC Client (32) | Creating socket. | 2017-10-04 05:11:14
DTC Client (32) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:14
DTC Client (32) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:15 *
DTC Client (32) | Initiating close of socket by core. | 2017-10-04 05:11:15
DTC Client (32) | Closed. | 2017-10-04 05:11:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:15
Rithmic Trading | Disconnected. | 2017-10-04 05:11:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:15
Rithmic Trading | Port for executable: 56345 | 2017-10-04 05:11:17
Listening socket (524), port 56345 | Closed. | 2017-10-04 05:11:17
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56345 | 2017-10-04 05:11:19
DTC Client (33) | Creating socket. | 2017-10-04 05:11:19
DTC Client (33) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:19
DTC Client (33) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:20 *
DTC Client (33) | Initiating close of socket by core. | 2017-10-04 05:11:20
DTC Client (33) | Closed. | 2017-10-04 05:11:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:20
Rithmic Trading | Disconnected. | 2017-10-04 05:11:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:20
Rithmic Trading | Port for executable: 56347 | 2017-10-04 05:11:22
Listening socket (636), port 56347 | Closed. | 2017-10-04 05:11:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56347 | 2017-10-04 05:11:24
DTC Client (34) | Creating socket. | 2017-10-04 05:11:24
DTC Client (34) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:24
Rithmic Trading | Connected to server. | 2017-10-04 05:11:24
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:11:24
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:11:24
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:11:24
Rithmic Trading | Sending logon request message. | 2017-10-04 05:11:24
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:11:24
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:11:24
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:11:24
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:11:26
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:11:26
Rithmic Trading | Received logon response. | 2017-10-04 05:11:26
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:11:26
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:11:26
Rithmic Trading | Logon error received from server | 2017-10-04 05:11:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:26
DTC Client (34) | Initiating close of socket by core. | 2017-10-04 05:11:26
DTC Client (34) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:11:26
DTC Client (34) | Socket gracefully closed by remote side. | 2017-10-04 05:11:26
DTC Client (34) | Closed. | 2017-10-04 05:11:26
Rithmic Trading | Disconnected. | 2017-10-04 05:11:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:26
Rithmic Trading | Port for executable: 56357 | 2017-10-04 05:11:28
Listening socket (544), port 56357 | Closed. | 2017-10-04 05:11:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:28
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56357 | 2017-10-04 05:11:30
DTC Client (35) | Creating socket. | 2017-10-04 05:11:30
DTC Client (35) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:30
DTC Client (35) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:31 *
DTC Client (35) | Initiating close of socket by core. | 2017-10-04 05:11:31
DTC Client (35) | Closed. | 2017-10-04 05:11:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:31
Rithmic Trading | Disconnected. | 2017-10-04 05:11:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:31
Rithmic Trading | Port for executable: 56359 | 2017-10-04 05:11:33
Listening socket (400), port 56359 | Closed. | 2017-10-04 05:11:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56359 | 2017-10-04 05:11:35
DTC Client (36) | Creating socket. | 2017-10-04 05:11:35
DTC Client (36) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:35
DTC Client (36) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:36 *
DTC Client (36) | Initiating close of socket by core. | 2017-10-04 05:11:36
DTC Client (36) | Closed. | 2017-10-04 05:11:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:36
Rithmic Trading | Disconnected. | 2017-10-04 05:11:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:36
Rithmic Trading | Port for executable: 56361 | 2017-10-04 05:11:38
Listening socket (632), port 56361 | Closed. | 2017-10-04 05:11:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56361 | 2017-10-04 05:11:40
DTC Client (37) | Creating socket. | 2017-10-04 05:11:40
DTC Client (37) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:40
DTC Client (37) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:41 *
DTC Client (37) | Initiating close of socket by core. | 2017-10-04 05:11:41
DTC Client (37) | Closed. | 2017-10-04 05:11:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:41
Rithmic Trading | Disconnected. | 2017-10-04 05:11:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:41
Rithmic Trading | Port for executable: 56363 | 2017-10-04 05:11:43
Listening socket (888), port 56363 | Closed. | 2017-10-04 05:11:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56363 | 2017-10-04 05:11:45
DTC Client (38) | Creating socket. | 2017-10-04 05:11:45
DTC Client (38) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:45
DTC Client (38) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:46 *
DTC Client (38) | Initiating close of socket by core. | 2017-10-04 05:11:46
DTC Client (38) | Closed. | 2017-10-04 05:11:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:46
Rithmic Trading | Disconnected. | 2017-10-04 05:11:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:46
Rithmic Trading | Port for executable: 56365 | 2017-10-04 05:11:48
Listening socket (600), port 56365 | Closed. | 2017-10-04 05:11:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56365 | 2017-10-04 05:11:50
DTC Client (39) | Creating socket. | 2017-10-04 05:11:50
DTC Client (39) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:50
Rithmic Trading | Connected to server. | 2017-10-04 05:11:50
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:11:50
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:11:50
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:11:50
Rithmic Trading | Sending logon request message. | 2017-10-04 05:11:50
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:11:50
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:11:50
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:11:50
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:11:52
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:11:52
Rithmic Trading | Received logon response. | 2017-10-04 05:11:52
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:11:52
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:11:52
Rithmic Trading | Logon error received from server | 2017-10-04 05:11:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:52
DTC Client (39) | Initiating close of socket by core. | 2017-10-04 05:11:52
DTC Client (39) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:11:52
DTC Client (39) | Socket gracefully closed by remote side. | 2017-10-04 05:11:52
Rithmic Trading | Disconnected. | 2017-10-04 05:11:52
DTC Client (39) | Closed. | 2017-10-04 05:11:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:52
Rithmic Trading | Port for executable: 56375 | 2017-10-04 05:11:54
Listening socket (920), port 56375 | Closed. | 2017-10-04 05:11:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56375 | 2017-10-04 05:11:56
DTC Client (40) | Creating socket. | 2017-10-04 05:11:56
DTC Client (40) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:11:56
DTC Client (40) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:11:57 *
DTC Client (40) | Initiating close of socket by core. | 2017-10-04 05:11:57
DTC Client (40) | Closed. | 2017-10-04 05:11:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:11:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:11:57
Rithmic Trading | Disconnected. | 2017-10-04 05:11:57
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:11:57
Rithmic Trading | Port for executable: 56377 | 2017-10-04 05:11:59
Listening socket (808), port 56377 | Closed. | 2017-10-04 05:11:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:11:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56377 | 2017-10-04 05:12:01
DTC Client (41) | Creating socket. | 2017-10-04 05:12:01
DTC Client (41) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:01
DTC Client (41) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:02 *
DTC Client (41) | Initiating close of socket by core. | 2017-10-04 05:12:02
DTC Client (41) | Closed. | 2017-10-04 05:12:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:02
Rithmic Trading | Disconnected. | 2017-10-04 05:12:02
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:02
Rithmic Trading | Port for executable: 56379 | 2017-10-04 05:12:04
Listening socket (808), port 56379 | Closed. | 2017-10-04 05:12:04
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56379 | 2017-10-04 05:12:06
DTC Client (42) | Creating socket. | 2017-10-04 05:12:06
DTC Client (42) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:06
DTC Client (42) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:07 *
DTC Client (42) | Initiating close of socket by core. | 2017-10-04 05:12:07
DTC Client (42) | Closed. | 2017-10-04 05:12:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:07
Rithmic Trading | Disconnected. | 2017-10-04 05:12:07
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:07
Rithmic Trading | Port for executable: 56381 | 2017-10-04 05:12:09
Listening socket (808), port 56381 | Closed. | 2017-10-04 05:12:09
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56381 | 2017-10-04 05:12:11
DTC Client (43) | Creating socket. | 2017-10-04 05:12:11
DTC Client (43) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:11
DTC Client (43) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:12 *
DTC Client (43) | Initiating close of socket by core. | 2017-10-04 05:12:12
DTC Client (43) | Closed. | 2017-10-04 05:12:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:12
Rithmic Trading | Disconnected. | 2017-10-04 05:12:12
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:12
Rithmic Trading | Port for executable: 56383 | 2017-10-04 05:12:14
Listening socket (876), port 56383 | Closed. | 2017-10-04 05:12:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56383 | 2017-10-04 05:12:16
DTC Client (44) | Creating socket. | 2017-10-04 05:12:16
DTC Client (44) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:16
Rithmic Trading | Connected to server. | 2017-10-04 05:12:16
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:12:16
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:12:16
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:12:16
Rithmic Trading | Sending logon request message. | 2017-10-04 05:12:16
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:12:16
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:12:16
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:12:16
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:12:17
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:12:18
Rithmic Trading | Received logon response. | 2017-10-04 05:12:18
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:12:18
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:12:18
Rithmic Trading | Logon error received from server | 2017-10-04 05:12:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:18
DTC Client (44) | Initiating close of socket by core. | 2017-10-04 05:12:18
Rithmic Trading | Disconnected. | 2017-10-04 05:12:18
DTC Client (44) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:12:18
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:18
DTC Client (44) | Socket gracefully closed by remote side. | 2017-10-04 05:12:18
DTC Client (44) | Closed. | 2017-10-04 05:12:18
Rithmic Trading | Port for executable: 56393 | 2017-10-04 05:12:20
Listening socket (920), port 56393 | Closed. | 2017-10-04 05:12:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56393 | 2017-10-04 05:12:22
DTC Client (45) | Creating socket. | 2017-10-04 05:12:22
DTC Client (45) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:22
DTC Client (45) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:23 *
DTC Client (45) | Initiating close of socket by core. | 2017-10-04 05:12:23
DTC Client (45) | Closed. | 2017-10-04 05:12:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:23
Rithmic Trading | Disconnected. | 2017-10-04 05:12:23
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:23
Rithmic Trading | Port for executable: 56395 | 2017-10-04 05:12:25
Listening socket (844), port 56395 | Closed. | 2017-10-04 05:12:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56395 | 2017-10-04 05:12:27
DTC Client (46) | Creating socket. | 2017-10-04 05:12:27
DTC Client (46) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:27
DTC Client (46) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:28 *
DTC Client (46) | Initiating close of socket by core. | 2017-10-04 05:12:28
DTC Client (46) | Closed. | 2017-10-04 05:12:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:28
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:28
Rithmic Trading | Disconnected. | 2017-10-04 05:12:28
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:28
Rithmic Trading | Port for executable: 56397 | 2017-10-04 05:12:30
Listening socket (992), port 56397 | Closed. | 2017-10-04 05:12:30
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56397 | 2017-10-04 05:12:32
DTC Client (47) | Creating socket. | 2017-10-04 05:12:32
DTC Client (47) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:32
DTC Client (47) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:33 *
DTC Client (47) | Initiating close of socket by core. | 2017-10-04 05:12:33
DTC Client (47) | Closed. | 2017-10-04 05:12:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:33
Rithmic Trading | Disconnected. | 2017-10-04 05:12:33
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:33
Rithmic Trading | Port for executable: 56399 | 2017-10-04 05:12:35
Listening socket (920), port 56399 | Closed. | 2017-10-04 05:12:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56399 | 2017-10-04 05:12:37
DTC Client (48) | Creating socket. | 2017-10-04 05:12:37
DTC Client (48) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:37
DTC Client (48) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:38 *
DTC Client (48) | Initiating close of socket by core. | 2017-10-04 05:12:38
DTC Client (48) | Closed. | 2017-10-04 05:12:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:38
Rithmic Trading | Disconnected. | 2017-10-04 05:12:38
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:38
Rithmic Trading | Port for executable: 56402 | 2017-10-04 05:12:40
Listening socket (524), port 56402 | Closed. | 2017-10-04 05:12:40
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56402 | 2017-10-04 05:12:42
DTC Client (49) | Creating socket. | 2017-10-04 05:12:42
DTC Client (49) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:42
Rithmic Trading | Connected to server. | 2017-10-04 05:12:42
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:12:42
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:12:42
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:12:42
Rithmic Trading | Sending logon request message. | 2017-10-04 05:12:42
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:12:42
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:12:42
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:12:42
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:12:43
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:12:43
Rithmic Trading | Received logon response. | 2017-10-04 05:12:43
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:12:43
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:12:43
Rithmic Trading | Logon error received from server | 2017-10-04 05:12:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:43
DTC Client (49) | Initiating close of socket by core. | 2017-10-04 05:12:43
DTC Client (49) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:12:43
DTC Client (49) | Socket gracefully closed by remote side. | 2017-10-04 05:12:43
DTC Client (49) | Closed. | 2017-10-04 05:12:43
Rithmic Trading | Disconnected. | 2017-10-04 05:12:43
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:43
Rithmic Trading | Port for executable: 56412 | 2017-10-04 05:12:45
Listening socket (600), port 56412 | Closed. | 2017-10-04 05:12:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56412 | 2017-10-04 05:12:47
DTC Client (50) | Creating socket. | 2017-10-04 05:12:47
DTC Client (50) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:47
DTC Client (50) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:48 *
DTC Client (50) | Initiating close of socket by core. | 2017-10-04 05:12:48
DTC Client (50) | Closed. | 2017-10-04 05:12:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:48
Rithmic Trading | Disconnected. | 2017-10-04 05:12:48
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:48
Rithmic Trading | Port for executable: 56415 | 2017-10-04 05:12:50
Listening socket (888), port 56415 | Closed. | 2017-10-04 05:12:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56415 | 2017-10-04 05:12:52
DTC Client (51) | Creating socket. | 2017-10-04 05:12:52
DTC Client (51) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:52
DTC Client (51) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:53 *
DTC Client (51) | Initiating close of socket by core. | 2017-10-04 05:12:53
DTC Client (51) | Closed. | 2017-10-04 05:12:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:53
Rithmic Trading | Disconnected. | 2017-10-04 05:12:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:53
Rithmic Trading | Port for executable: 56417 | 2017-10-04 05:12:55
Listening socket (600), port 56417 | Closed. | 2017-10-04 05:12:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:12:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56417 | 2017-10-04 05:12:57
DTC Client (52) | Creating socket. | 2017-10-04 05:12:57
DTC Client (52) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:12:57
DTC Client (52) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:12:58 *
DTC Client (52) | Initiating close of socket by core. | 2017-10-04 05:12:58
DTC Client (52) | Closed. | 2017-10-04 05:12:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:12:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:12:58
Rithmic Trading | Disconnected. | 2017-10-04 05:12:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:12:58
Rithmic Trading | Port for executable: 56419 | 2017-10-04 05:13:00
Listening socket (600), port 56419 | Closed. | 2017-10-04 05:13:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:13:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56419 | 2017-10-04 05:13:02
DTC Client (53) | Creating socket. | 2017-10-04 05:13:02
DTC Client (53) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:13:02
DTC Client (53) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-10-04 05:13:03 *
DTC Client (53) | Initiating close of socket by core. | 2017-10-04 05:13:03
DTC Client (53) | Closed. | 2017-10-04 05:13:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:13:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:13:03
Rithmic Trading | Disconnected. | 2017-10-04 05:13:03
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:13:03
Rithmic Trading | Port for executable: 56451 | 2017-10-04 05:15:03
Listening socket (920), port 56451 | Closed. | 2017-10-04 05:15:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:15:03
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56451 | 2017-10-04 05:15:05
DTC Client (55) | Creating socket. | 2017-10-04 05:15:05
DTC Client (55) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:15:05
Rithmic Trading | Connected to server. | 2017-10-04 05:15:05
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:15:05
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:15:05
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:15:05
Rithmic Trading | Sending logon request message. | 2017-10-04 05:15:05
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:15:05
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:15:05
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:15:05
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:15:07
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:15:07
Rithmic Trading | Received logon response. | 2017-10-04 05:15:07
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:15:07
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:15:07
Rithmic Trading | Logon error received from server | 2017-10-04 05:15:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:15:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:15:07
DTC Client (55) | Initiating close of socket by core. | 2017-10-04 05:15:07
DTC Client (55) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:15:07
DTC Client (55) | Socket gracefully closed by remote side. | 2017-10-04 05:15:07
Rithmic Trading | Disconnected. | 2017-10-04 05:15:07
DTC Client (55) | Closed. | 2017-10-04 05:15:07
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:15:07
Rithmic Trading | Port for executable: 56467 | 2017-10-04 05:17:07
Listening socket (1068), port 56467 | Closed. | 2017-10-04 05:17:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:17:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56467 | 2017-10-04 05:17:09
DTC Client (56) | Creating socket. | 2017-10-04 05:17:09
DTC Client (56) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:17:09
Rithmic Trading | Connected to server. | 2017-10-04 05:17:09
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:17:09
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:17:09
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:17:10
Rithmic Trading | Sending logon request message. | 2017-10-04 05:17:10
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:17:10
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:17:10
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:17:10
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:17:11
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:17:11
Rithmic Trading | Received logon response. | 2017-10-04 05:17:11
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:17:11
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:17:11
Rithmic Trading | Logon error received from server | 2017-10-04 05:17:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:17:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:17:11
DTC Client (56) | Initiating close of socket by core. | 2017-10-04 05:17:11
Rithmic Trading | Disconnected. | 2017-10-04 05:17:11
DTC Client (56) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:17:11
DTC Client (56) | Socket gracefully closed by remote side. | 2017-10-04 05:17:11
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:17:11
DTC Client (56) | Closed. | 2017-10-04 05:17:11
Rithmic Trading | Port for executable: 56599 | 2017-10-04 05:19:11
Listening socket (1060), port 56599 | Closed. | 2017-10-04 05:19:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:19:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56599 | 2017-10-04 05:19:13
DTC Client (58) | Creating socket. | 2017-10-04 05:19:13
DTC Client (58) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:19:13
Rithmic Trading | Connected to server. | 2017-10-04 05:19:13
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:19:13
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:19:13
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:19:14
Rithmic Trading | Sending logon request message. | 2017-10-04 05:19:14
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:19:14
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:19:14
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:19:14
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:19:15
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:19:16
Rithmic Trading | Received logon response. | 2017-10-04 05:19:16
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:19:16
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:19:16
Rithmic Trading | Logon error received from server | 2017-10-04 05:19:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:19:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:19:16
DTC Client (58) | Initiating close of socket by core. | 2017-10-04 05:19:16
DTC Client (58) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:19:16
DTC Client (58) | Socket gracefully closed by remote side. | 2017-10-04 05:19:16
Rithmic Trading | Disconnected. | 2017-10-04 05:19:16
DTC Client (58) | Closed. | 2017-10-04 05:19:16
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:19:16
Rithmic Trading | Port for executable: 56648 | 2017-10-04 05:21:16
Listening socket (1068), port 56648 | Closed. | 2017-10-04 05:21:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:21:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56648 | 2017-10-04 05:21:18
DTC Client (59) | Creating socket. | 2017-10-04 05:21:18
DTC Client (59) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:21:18
Rithmic Trading | Connected to server. | 2017-10-04 05:21:18
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:21:18
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:21:18
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:21:18
Rithmic Trading | Sending logon request message. | 2017-10-04 05:21:18
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:21:18
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:21:18
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:21:18
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:21:20
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:21:20
Rithmic Trading | Received logon response. | 2017-10-04 05:21:20
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:21:20
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:21:20
Rithmic Trading | Logon error received from server | 2017-10-04 05:21:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:21:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:21:20
DTC Client (59) | Initiating close of socket by core. | 2017-10-04 05:21:20
DTC Client (59) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:21:20
DTC Client (59) | Socket gracefully closed by remote side. | 2017-10-04 05:21:20
Rithmic Trading | Disconnected. | 2017-10-04 05:21:20
DTC Client (59) | Closed. | 2017-10-04 05:21:20
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:21:20
Rithmic Trading | Port for executable: 56676 | 2017-10-04 05:23:20
Listening socket (1080), port 56676 | Closed. | 2017-10-04 05:23:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:23:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56676 | 2017-10-04 05:23:22
DTC Client (60) | Creating socket. | 2017-10-04 05:23:22
DTC Client (60) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:23:22
Rithmic Trading | Connected to server. | 2017-10-04 05:23:22
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:23:22
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:23:22
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:23:22
Rithmic Trading | Sending logon request message. | 2017-10-04 05:23:22
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:23:22
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:23:22
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:23:22
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:23:23
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:23:23
Rithmic Trading | Received logon response. | 2017-10-04 05:23:23
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:23:23
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:23:23
Rithmic Trading | Logon error received from server | 2017-10-04 05:23:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:23:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:23:23
DTC Client (60) | Initiating close of socket by core. | 2017-10-04 05:23:23
DTC Client (60) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:23:23
DTC Client (60) | Socket gracefully closed by remote side. | 2017-10-04 05:23:23
DTC Client (60) | Closed. | 2017-10-04 05:23:23
Rithmic Trading | Disconnected. | 2017-10-04 05:23:23
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:23:23
Rithmic Trading | Port for executable: 56722 | 2017-10-04 05:25:23
Listening socket (888), port 56722 | Closed. | 2017-10-04 05:25:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:25:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56722 | 2017-10-04 05:25:25
DTC Client (62) | Creating socket. | 2017-10-04 05:25:25
DTC Client (62) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:25:25
Rithmic Trading | Connected to server. | 2017-10-04 05:25:25
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:25:25
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:25:25
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:25:25
Rithmic Trading | Sending logon request message. | 2017-10-04 05:25:25
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:25:25
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:25:25
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:25:25
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:25:27
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:25:27
Rithmic Trading | Received logon response. | 2017-10-04 05:25:27
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:25:27
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:25:27
Rithmic Trading | Logon error received from server | 2017-10-04 05:25:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:25:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:25:27
DTC Client (62) | Initiating close of socket by core. | 2017-10-04 05:25:27
DTC Client (62) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:25:27
DTC Client (62) | Socket gracefully closed by remote side. | 2017-10-04 05:25:27
DTC Client (62) | Closed. | 2017-10-04 05:25:27
Rithmic Trading | Disconnected. | 2017-10-04 05:25:27
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:25:27
Rithmic Trading | Port for executable: 56913 | 2017-10-04 05:27:27
Listening socket (920), port 56913 | Closed. | 2017-10-04 05:27:27
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:27:27
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56913 | 2017-10-04 05:27:29
DTC Client (63) | Creating socket. | 2017-10-04 05:27:29
DTC Client (63) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:27:29
Rithmic Trading | Connected to server. | 2017-10-04 05:27:29
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:27:29
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:27:29
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:27:29
Rithmic Trading | Sending logon request message. | 2017-10-04 05:27:29
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:27:29
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:27:29
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:27:29
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:27:30
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:27:31
Rithmic Trading | Received logon response. | 2017-10-04 05:27:31
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:27:31
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:27:31
Rithmic Trading | Logon error received from server | 2017-10-04 05:27:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:27:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:27:31
DTC Client (63) | Initiating close of socket by core. | 2017-10-04 05:27:31
Rithmic Trading | Disconnected. | 2017-10-04 05:27:31
DTC Client (63) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:27:31
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:27:31
DTC Client (63) | Socket gracefully closed by remote side. | 2017-10-04 05:27:31
DTC Client (63) | Closed. | 2017-10-04 05:27:31
Rithmic Trading | Port for executable: 56925 | 2017-10-04 05:29:31
Listening socket (1128), port 56925 | Closed. | 2017-10-04 05:29:31
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:29:31
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56925 | 2017-10-04 05:29:33
DTC Client (65) | Creating socket. | 2017-10-04 05:29:33
DTC Client (65) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:29:33
Rithmic Trading | Connected to server. | 2017-10-04 05:29:33
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:29:33
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:29:33
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:29:33
Rithmic Trading | Sending logon request message. | 2017-10-04 05:29:33
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:29:33
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:29:33
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:29:33
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:29:34
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:29:34
Rithmic Trading | Received logon response. | 2017-10-04 05:29:34
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:29:34
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:29:34
Rithmic Trading | Logon error received from server | 2017-10-04 05:29:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:29:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:29:34
DTC Client (65) | Initiating close of socket by core. | 2017-10-04 05:29:34
DTC Client (65) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:29:34
DTC Client (65) | Socket gracefully closed by remote side. | 2017-10-04 05:29:34
Rithmic Trading | Disconnected. | 2017-10-04 05:29:34
DTC Client (65) | Closed. | 2017-10-04 05:29:34
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:29:34
Rithmic Trading | Port for executable: 57029 | 2017-10-04 05:31:34
Listening socket (808), port 57029 | Closed. | 2017-10-04 05:31:34
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:31:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57029 | 2017-10-04 05:31:36
DTC Client (66) | Creating socket. | 2017-10-04 05:31:36
DTC Client (66) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:31:36
Rithmic Trading | Connected to server. | 2017-10-04 05:31:36
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:31:36
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:31:36
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:31:36
Rithmic Trading | Sending logon request message. | 2017-10-04 05:31:36
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:31:36
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:31:36
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:31:36
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:31:38
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:31:38
Rithmic Trading | Received logon response. | 2017-10-04 05:31:38
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:31:38
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:31:38
Rithmic Trading | Logon error received from server | 2017-10-04 05:31:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:31:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:31:38
DTC Client (66) | Initiating close of socket by core. | 2017-10-04 05:31:38
DTC Client (66) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:31:38
DTC Client (66) | Socket gracefully closed by remote side. | 2017-10-04 05:31:38
DTC Client (66) | Closed. | 2017-10-04 05:31:38
Rithmic Trading | Disconnected. | 2017-10-04 05:31:38
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:31:38
Rithmic Trading | Port for executable: 57077 | 2017-10-04 05:33:38
Listening socket (808), port 57077 | Closed. | 2017-10-04 05:33:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:33:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57077 | 2017-10-04 05:33:40
DTC Client (67) | Creating socket. | 2017-10-04 05:33:40
DTC Client (67) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:33:40
Rithmic Trading | Connected to server. | 2017-10-04 05:33:40
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:33:40
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:33:40
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:33:40
Rithmic Trading | Sending logon request message. | 2017-10-04 05:33:40
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:33:40
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:33:40
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:33:40
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:33:41
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:33:41
Rithmic Trading | Received logon response. | 2017-10-04 05:33:41
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:33:41
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:33:41
Rithmic Trading | Logon error received from server | 2017-10-04 05:33:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:33:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:33:41
DTC Client (67) | Initiating close of socket by core. | 2017-10-04 05:33:41
DTC Client (67) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:33:41
DTC Client (67) | Socket gracefully closed by remote side. | 2017-10-04 05:33:41
Rithmic Trading | Disconnected. | 2017-10-04 05:33:41
DTC Client (67) | Closed. | 2017-10-04 05:33:41
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:33:41
Rithmic Trading | Port for executable: 57108 | 2017-10-04 05:35:41
Listening socket (544), port 57108 | Closed. | 2017-10-04 05:35:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:35:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57108 | 2017-10-04 05:35:43
DTC Client (69) | Creating socket. | 2017-10-04 05:35:43
DTC Client (69) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:35:43
Rithmic Trading | Connected to server. | 2017-10-04 05:35:43
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:35:43
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:35:43
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:35:43
Rithmic Trading | Sending logon request message. | 2017-10-04 05:35:43
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:35:43
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:35:43
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:35:43
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:35:45
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:35:45
Rithmic Trading | Received logon response. | 2017-10-04 05:35:45
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:35:45
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:35:45
Rithmic Trading | Logon error received from server | 2017-10-04 05:35:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:35:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:35:45
DTC Client (69) | Initiating close of socket by core. | 2017-10-04 05:35:45
DTC Client (69) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:35:45
DTC Client (69) | Socket gracefully closed by remote side. | 2017-10-04 05:35:45
Rithmic Trading | Disconnected. | 2017-10-04 05:35:45
DTC Client (69) | Closed. | 2017-10-04 05:35:45
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:35:45
Rithmic Trading | Port for executable: 57231 | 2017-10-04 05:37:45
Listening socket (1080), port 57231 | Closed. | 2017-10-04 05:37:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:37:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57231 | 2017-10-04 05:37:47
DTC Client (70) | Creating socket. | 2017-10-04 05:37:47
DTC Client (70) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:37:47
Rithmic Trading | Connected to server. | 2017-10-04 05:37:47
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:37:47
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:37:47
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:37:47
Rithmic Trading | Sending logon request message. | 2017-10-04 05:37:47
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:37:47
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:37:47
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:37:47
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:37:48
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:37:49
Rithmic Trading | Received logon response. | 2017-10-04 05:37:49
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:37:49
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:37:49
Rithmic Trading | Logon error received from server | 2017-10-04 05:37:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:37:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:37:49
DTC Client (70) | Initiating close of socket by core. | 2017-10-04 05:37:49
DTC Client (70) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:37:49
DTC Client (70) | Socket gracefully closed by remote side. | 2017-10-04 05:37:49
DTC Client (70) | Closed. | 2017-10-04 05:37:49
Rithmic Trading | Disconnected. | 2017-10-04 05:37:49
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:37:49
Sierra Chart account data changed. Requesting updated account information. | 2017-10-04 05:38:43
Successfully processed Sierra Chart account data. | 2017-10-04 05:38:44
Rithmic Trading | Port for executable: 57254 | 2017-10-04 05:39:49
Listening socket (600), port 57254 | Closed. | 2017-10-04 05:39:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:39:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57254 | 2017-10-04 05:39:51
DTC Client (73) | Creating socket. | 2017-10-04 05:39:51
DTC Client (73) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:39:51
Rithmic Trading | Connected to server. | 2017-10-04 05:39:51
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:39:51
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:39:51
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:39:51
Rithmic Trading | Sending logon request message. | 2017-10-04 05:39:51
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:39:51
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:39:51
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:39:51
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:39:52
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:39:52
Rithmic Trading | Received logon response. | 2017-10-04 05:39:52
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:39:52
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:39:52
Rithmic Trading | Logon error received from server | 2017-10-04 05:39:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:39:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:39:52
DTC Client (73) | Initiating close of socket by core. | 2017-10-04 05:39:52
DTC Client (73) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:39:52
DTC Client (73) | Socket gracefully closed by remote side. | 2017-10-04 05:39:52
DTC Client (73) | Closed. | 2017-10-04 05:39:52
Rithmic Trading | Disconnected. | 2017-10-04 05:39:52
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:39:52
Rithmic Trading | Port for executable: 57289 | 2017-10-04 05:41:52
Listening socket (632), port 57289 | Closed. | 2017-10-04 05:41:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:41:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57289 | 2017-10-04 05:41:54
DTC Client (74) | Creating socket. | 2017-10-04 05:41:54
DTC Client (74) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:41:54
Rithmic Trading | Connected to server. | 2017-10-04 05:41:54
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:41:54
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:41:54
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:41:54
Rithmic Trading | Sending logon request message. | 2017-10-04 05:41:54
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:41:54
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:41:54
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:41:54
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:41:56
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:41:56
Rithmic Trading | Received logon response. | 2017-10-04 05:41:56
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:41:56
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:41:56
Rithmic Trading | Logon error received from server | 2017-10-04 05:41:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:41:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:41:56
DTC Client (74) | Initiating close of socket by core. | 2017-10-04 05:41:56
DTC Client (74) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:41:56
DTC Client (74) | Socket gracefully closed by remote side. | 2017-10-04 05:41:56
DTC Client (74) | Closed. | 2017-10-04 05:41:56
Rithmic Trading | Disconnected. | 2017-10-04 05:41:56
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:41:56
Rithmic Trading | Port for executable: 57410 | 2017-10-04 05:43:56
Listening socket (888), port 57410 | Closed. | 2017-10-04 05:43:56
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:43:56
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57410 | 2017-10-04 05:43:58
DTC Client (76) | Creating socket. | 2017-10-04 05:43:58
DTC Client (76) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:43:58
Rithmic Trading | Connected to server. | 2017-10-04 05:43:58
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:43:58
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:43:58
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:43:58
Rithmic Trading | Sending logon request message. | 2017-10-04 05:43:58
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:43:58
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:43:58
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:43:58
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:43:59
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:44:00
Rithmic Trading | Received logon response. | 2017-10-04 05:44:00
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:44:00
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:44:00
Rithmic Trading | Logon error received from server | 2017-10-04 05:44:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:44:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:44:00
DTC Client (76) | Initiating close of socket by core. | 2017-10-04 05:44:00
DTC Client (76) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:44:00
DTC Client (76) | Socket gracefully closed by remote side. | 2017-10-04 05:44:00
Rithmic Trading | Disconnected. | 2017-10-04 05:44:00
DTC Client (76) | Closed. | 2017-10-04 05:44:00
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:44:00
Rithmic Trading | Port for executable: 57494 | 2017-10-04 05:46:00
Listening socket (1048), port 57494 | Closed. | 2017-10-04 05:46:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:46:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57494 | 2017-10-04 05:46:02
DTC Client (77) | Creating socket. | 2017-10-04 05:46:02
DTC Client (77) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:46:02
Rithmic Trading | Connected to server. | 2017-10-04 05:46:02
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:46:02
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:46:02
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:46:02
Rithmic Trading | Sending logon request message. | 2017-10-04 05:46:02
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:46:02
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:46:02
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:46:02
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:46:03
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:46:03
Rithmic Trading | Received logon response. | 2017-10-04 05:46:03
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:46:03
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:46:03
Rithmic Trading | Logon error received from server | 2017-10-04 05:46:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:46:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:46:03
DTC Client (77) | Initiating close of socket by core. | 2017-10-04 05:46:03
DTC Client (77) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:46:03
DTC Client (77) | Socket gracefully closed by remote side. | 2017-10-04 05:46:03
DTC Client (77) | Closed. | 2017-10-04 05:46:03
Rithmic Trading | Disconnected. | 2017-10-04 05:46:03
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:46:03
Rithmic Trading | Port for executable: 57639 | 2017-10-04 05:48:03
Listening socket (400), port 57639 | Closed. | 2017-10-04 05:48:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:48:03
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57639 | 2017-10-04 05:48:05
DTC Client (78) | Creating socket. | 2017-10-04 05:48:05
DTC Client (78) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:48:05
Rithmic Trading | Connected to server. | 2017-10-04 05:48:05
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:48:05
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:48:05
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:48:06
Rithmic Trading | Sending logon request message. | 2017-10-04 05:48:06
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:48:06
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:48:06
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:48:06
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:48:07
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:48:07
Rithmic Trading | Received logon response. | 2017-10-04 05:48:07
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:48:07
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:48:07
Rithmic Trading | Logon error received from server | 2017-10-04 05:48:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:48:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:48:07
DTC Client (78) | Initiating close of socket by core. | 2017-10-04 05:48:07
DTC Client (78) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:48:07
DTC Client (78) | Socket gracefully closed by remote side. | 2017-10-04 05:48:07
Rithmic Trading | Disconnected. | 2017-10-04 05:48:07
DTC Client (78) | Closed. | 2017-10-04 05:48:07
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:48:07
Rithmic Trading | Port for executable: 57768 | 2017-10-04 05:50:07
Listening socket (1192), port 57768 | Closed. | 2017-10-04 05:50:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:50:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57768 | 2017-10-04 05:50:09
DTC Client (80) | Creating socket. | 2017-10-04 05:50:09
DTC Client (80) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:50:09
Rithmic Trading | Connected to server. | 2017-10-04 05:50:09
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:50:09
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:50:09
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:50:10
Rithmic Trading | Sending logon request message. | 2017-10-04 05:50:10
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:50:10
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:50:10
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:50:10
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:50:12
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:50:12
Rithmic Trading | Received logon response. | 2017-10-04 05:50:12
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:50:12
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:50:12
Rithmic Trading | Logon error received from server | 2017-10-04 05:50:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:50:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:50:12
DTC Client (80) | Initiating close of socket by core. | 2017-10-04 05:50:12
DTC Client (80) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:50:12
DTC Client (80) | Socket gracefully closed by remote side. | 2017-10-04 05:50:12
Rithmic Trading | Disconnected. | 2017-10-04 05:50:12
DTC Client (80) | Closed. | 2017-10-04 05:50:12
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:50:12
Rithmic Trading | Port for executable: 57847 | 2017-10-04 05:52:12
Listening socket (1036), port 57847 | Closed. | 2017-10-04 05:52:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:52:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57847 | 2017-10-04 05:52:14
DTC Client (81) | Creating socket. | 2017-10-04 05:52:14
DTC Client (81) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:52:14
Rithmic Trading | Connected to server. | 2017-10-04 05:52:14
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:52:14
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:52:14
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:52:14
Rithmic Trading | Sending logon request message. | 2017-10-04 05:52:14
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:52:14
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:52:14
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:52:14
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:52:15
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:52:15
Rithmic Trading | Received logon response. | 2017-10-04 05:52:15
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:52:15
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:52:15
Rithmic Trading | Logon error received from server | 2017-10-04 05:52:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:52:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:52:15
DTC Client (81) | Initiating close of socket by core. | 2017-10-04 05:52:15
DTC Client (81) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:52:15
DTC Client (81) | Socket gracefully closed by remote side. | 2017-10-04 05:52:15
Rithmic Trading | Disconnected. | 2017-10-04 05:52:15
DTC Client (81) | Closed. | 2017-10-04 05:52:15
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:52:15
Rithmic Trading | Port for executable: 57919 | 2017-10-04 05:54:15
Listening socket (844), port 57919 | Closed. | 2017-10-04 05:54:15
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:54:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57919 | 2017-10-04 05:54:17
DTC Client (83) | Creating socket. | 2017-10-04 05:54:17
DTC Client (83) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:54:17
Rithmic Trading | Connected to server. | 2017-10-04 05:54:17
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:54:17
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:54:17
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:54:17
Rithmic Trading | Sending logon request message. | 2017-10-04 05:54:17
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:54:17
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:54:17
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:54:17
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:54:19
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:54:19
Rithmic Trading | Received logon response. | 2017-10-04 05:54:19
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:54:19
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:54:19
Rithmic Trading | Logon error received from server | 2017-10-04 05:54:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:54:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:54:19
DTC Client (83) | Initiating close of socket by core. | 2017-10-04 05:54:19
Rithmic Trading | Disconnected. | 2017-10-04 05:54:19
DTC Client (83) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:54:19
DTC Client (83) | Socket gracefully closed by remote side. | 2017-10-04 05:54:19
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:54:19
DTC Client (83) | Closed. | 2017-10-04 05:54:19
Rithmic Trading | Port for executable: 58008 | 2017-10-04 05:56:19
Listening socket (1068), port 58008 | Closed. | 2017-10-04 05:56:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:56:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58008 | 2017-10-04 05:56:21
DTC Client (84) | Creating socket. | 2017-10-04 05:56:21
DTC Client (84) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:56:21
Rithmic Trading | Connected to server. | 2017-10-04 05:56:21
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:56:21
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:56:21
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:56:21
Rithmic Trading | Sending logon request message. | 2017-10-04 05:56:21
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:56:21
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:56:21
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:56:21
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:56:22
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:56:23
Rithmic Trading | Received logon response. | 2017-10-04 05:56:23
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:56:23
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:56:23
Rithmic Trading | Logon error received from server | 2017-10-04 05:56:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:56:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:56:23
DTC Client (84) | Initiating close of socket by core. | 2017-10-04 05:56:23
DTC Client (84) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:56:23
DTC Client (84) | Socket gracefully closed by remote side. | 2017-10-04 05:56:23
DTC Client (84) | Closed. | 2017-10-04 05:56:23
Rithmic Trading | Disconnected. | 2017-10-04 05:56:23
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:56:23
Rithmic Trading | Port for executable: 58021 | 2017-10-04 05:58:23
Listening socket (1072), port 58021 | Closed. | 2017-10-04 05:58:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 05:58:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58021 | 2017-10-04 05:58:25
DTC Client (85) | Creating socket. | 2017-10-04 05:58:25
DTC Client (85) | Connecting to IP: 127.0.0.1. | 2017-10-04 05:58:25
Rithmic Trading | Connected to server. | 2017-10-04 05:58:25
Rithmic Trading | Starting socket receive thread. | 2017-10-04 05:58:25
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 05:58:25
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 05:58:25
Rithmic Trading | Sending logon request message. | 2017-10-04 05:58:25
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 05:58:25
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 05:58:25
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 05:58:25
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 05:58:26
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 05:58:26
Rithmic Trading | Received logon response. | 2017-10-04 05:58:26
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 05:58:26
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 05:58:26
Rithmic Trading | Logon error received from server | 2017-10-04 05:58:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 05:58:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 05:58:26
DTC Client (85) | Initiating close of socket by core. | 2017-10-04 05:58:26
DTC Client (85) | Shutdown started. Waiting for graceful close. | 2017-10-04 05:58:26
DTC Client (85) | Socket gracefully closed by remote side. | 2017-10-04 05:58:26
DTC Client (85) | Closed. | 2017-10-04 05:58:26
Rithmic Trading | Disconnected. | 2017-10-04 05:58:26
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 05:58:26
Rithmic Trading | Port for executable: 58071 | 2017-10-04 06:00:26
Listening socket (1048), port 58071 | Closed. | 2017-10-04 06:00:26
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:00:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58071 | 2017-10-04 06:00:28
DTC Client (87) | Creating socket. | 2017-10-04 06:00:28
DTC Client (87) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:00:28
Rithmic Trading | Connected to server. | 2017-10-04 06:00:28
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:00:28
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:00:28
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:00:28
Rithmic Trading | Sending logon request message. | 2017-10-04 06:00:28
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:00:28
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:00:28
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:00:28
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:00:30
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:00:30
Rithmic Trading | Received logon response. | 2017-10-04 06:00:30
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:00:30
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:00:30
Rithmic Trading | Logon error received from server | 2017-10-04 06:00:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:00:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:00:30
DTC Client (87) | Initiating close of socket by core. | 2017-10-04 06:00:30
Rithmic Trading | Disconnected. | 2017-10-04 06:00:30
DTC Client (87) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:00:30
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:00:30
DTC Client (87) | Socket gracefully closed by remote side. | 2017-10-04 06:00:30
DTC Client (87) | Closed. | 2017-10-04 06:00:30
Rithmic Trading | Port for executable: 58086 | 2017-10-04 06:02:30
Listening socket (844), port 58086 | Closed. | 2017-10-04 06:02:30
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:02:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58086 | 2017-10-04 06:02:32
DTC Client (88) | Creating socket. | 2017-10-04 06:02:32
DTC Client (88) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:02:32
Rithmic Trading | Connected to server. | 2017-10-04 06:02:32
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:02:32
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:02:32
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:02:32
Rithmic Trading | Sending logon request message. | 2017-10-04 06:02:32
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:02:32
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:02:32
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:02:32
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:02:33
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:02:34
Rithmic Trading | Received logon response. | 2017-10-04 06:02:34
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:02:34
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:02:34
Rithmic Trading | Logon error received from server | 2017-10-04 06:02:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:02:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:02:34
DTC Client (88) | Initiating close of socket by core. | 2017-10-04 06:02:34
DTC Client (88) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:02:34
DTC Client (88) | Socket gracefully closed by remote side. | 2017-10-04 06:02:34
DTC Client (88) | Closed. | 2017-10-04 06:02:34
Rithmic Trading | Disconnected. | 2017-10-04 06:02:34
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:02:34
Rithmic Trading | Port for executable: 58099 | 2017-10-04 06:04:34
Listening socket (1076), port 58099 | Closed. | 2017-10-04 06:04:34
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:04:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58099 | 2017-10-04 06:04:36
DTC Client (90) | Creating socket. | 2017-10-04 06:04:36
DTC Client (90) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:04:36
Rithmic Trading | Connected to server. | 2017-10-04 06:04:36
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:04:36
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:04:36
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:04:36
Rithmic Trading | Sending logon request message. | 2017-10-04 06:04:36
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:04:36
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:04:36
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:04:36
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:04:37
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:04:37
Rithmic Trading | Received logon response. | 2017-10-04 06:04:37
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:04:37
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:04:37
Rithmic Trading | Logon error received from server | 2017-10-04 06:04:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:04:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:04:37
DTC Client (90) | Initiating close of socket by core. | 2017-10-04 06:04:37
DTC Client (90) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:04:37
DTC Client (90) | Socket gracefully closed by remote side. | 2017-10-04 06:04:37
Rithmic Trading | Disconnected. | 2017-10-04 06:04:37
DTC Client (90) | Closed. | 2017-10-04 06:04:37
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:04:37
Rithmic Trading | Port for executable: 58113 | 2017-10-04 06:06:37
Listening socket (1068), port 58113 | Closed. | 2017-10-04 06:06:37
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:06:37
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58113 | 2017-10-04 06:06:39
DTC Client (91) | Creating socket. | 2017-10-04 06:06:39
DTC Client (91) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:06:39
Rithmic Trading | Connected to server. | 2017-10-04 06:06:39
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:06:39
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:06:39
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:06:39
Rithmic Trading | Sending logon request message. | 2017-10-04 06:06:39
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:06:39
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:06:39
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:06:39
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:06:41
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:06:41
Rithmic Trading | Received logon response. | 2017-10-04 06:06:41
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:06:41
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:06:41
Rithmic Trading | Logon error received from server | 2017-10-04 06:06:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:06:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:06:41
DTC Client (91) | Initiating close of socket by core. | 2017-10-04 06:06:41
Rithmic Trading | Disconnected. | 2017-10-04 06:06:41
DTC Client (91) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:06:41
DTC Client (91) | Socket gracefully closed by remote side. | 2017-10-04 06:06:41
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:06:41
DTC Client (91) | Closed. | 2017-10-04 06:06:41
Rithmic Trading | Port for executable: 58123 | 2017-10-04 06:08:41
Listening socket (1076), port 58123 | Closed. | 2017-10-04 06:08:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:08:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58123 | 2017-10-04 06:08:43
DTC Client (93) | Creating socket. | 2017-10-04 06:08:43
DTC Client (93) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:08:43
Rithmic Trading | Connected to server. | 2017-10-04 06:08:43
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:08:43
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:08:43
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:08:43
Rithmic Trading | Sending logon request message. | 2017-10-04 06:08:43
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:08:43
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:08:43
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:08:43
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:08:44
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:08:44
Rithmic Trading | Received logon response. | 2017-10-04 06:08:44
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:08:44
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:08:44
Rithmic Trading | Logon error received from server | 2017-10-04 06:08:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:08:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:08:44
DTC Client (93) | Initiating close of socket by core. | 2017-10-04 06:08:44
Rithmic Trading | Disconnected. | 2017-10-04 06:08:44
DTC Client (93) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:08:44
DTC Client (93) | Socket gracefully closed by remote side. | 2017-10-04 06:08:44
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:08:44
DTC Client (93) | Closed. | 2017-10-04 06:08:44
Rithmic Trading | Port for executable: 58137 | 2017-10-04 06:10:44
Listening socket (1048), port 58137 | Closed. | 2017-10-04 06:10:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:10:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58137 | 2017-10-04 06:10:46
DTC Client (94) | Creating socket. | 2017-10-04 06:10:46
DTC Client (94) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:10:46
Rithmic Trading | Connected to server. | 2017-10-04 06:10:46
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:10:46
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:10:46
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:10:46
Rithmic Trading | Sending logon request message. | 2017-10-04 06:10:46
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:10:46
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:10:46
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:10:46
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:10:48
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:10:48
Rithmic Trading | Received logon response. | 2017-10-04 06:10:48
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:10:48
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:10:48
Rithmic Trading | Logon error received from server | 2017-10-04 06:10:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:10:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:10:48
DTC Client (94) | Initiating close of socket by core. | 2017-10-04 06:10:48
DTC Client (94) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:10:48
DTC Client (94) | Socket gracefully closed by remote side. | 2017-10-04 06:10:48
Rithmic Trading | Disconnected. | 2017-10-04 06:10:48
DTC Client (94) | Closed. | 2017-10-04 06:10:48
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:10:48
Rithmic Trading | Port for executable: 58148 | 2017-10-04 06:12:48
Listening socket (920), port 58148 | Closed. | 2017-10-04 06:12:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:12:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58148 | 2017-10-04 06:12:50
DTC Client (95) | Creating socket. | 2017-10-04 06:12:50
DTC Client (95) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:12:50
Rithmic Trading | Connected to server. | 2017-10-04 06:12:50
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:12:50
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:12:50
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:12:50
Rithmic Trading | Sending logon request message. | 2017-10-04 06:12:50
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:12:50
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:12:50
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:12:50
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:12:52
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:12:52
Rithmic Trading | Received logon response. | 2017-10-04 06:12:52
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:12:52
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:12:52
Rithmic Trading | Logon error received from server | 2017-10-04 06:12:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:12:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:12:52
DTC Client (95) | Initiating close of socket by core. | 2017-10-04 06:12:52
Rithmic Trading | Disconnected. | 2017-10-04 06:12:52
DTC Client (95) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:12:52
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:12:52
DTC Client (95) | Socket gracefully closed by remote side. | 2017-10-04 06:12:52
DTC Client (95) | Closed. | 2017-10-04 06:12:52
Rithmic Trading | Port for executable: 58162 | 2017-10-04 06:14:52
Listening socket (1104), port 58162 | Closed. | 2017-10-04 06:14:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:14:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58162 | 2017-10-04 06:14:54
DTC Client (97) | Creating socket. | 2017-10-04 06:14:54
DTC Client (97) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:14:54
Rithmic Trading | Connected to server. | 2017-10-04 06:14:54
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:14:54
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:14:54
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:14:54
Rithmic Trading | Sending logon request message. | 2017-10-04 06:14:54
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:14:54
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:14:54
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:14:54
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:14:55
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:14:55
Rithmic Trading | Received logon response. | 2017-10-04 06:14:55
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:14:55
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:14:55
Rithmic Trading | Logon error received from server | 2017-10-04 06:14:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:14:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:14:55
DTC Client (97) | Initiating close of socket by core. | 2017-10-04 06:14:55
DTC Client (97) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:14:55
DTC Client (97) | Socket gracefully closed by remote side. | 2017-10-04 06:14:55
Rithmic Trading | Disconnected. | 2017-10-04 06:14:55
DTC Client (97) | Closed. | 2017-10-04 06:14:55
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:14:55
Rithmic Trading | Port for executable: 58175 | 2017-10-04 06:16:55
Listening socket (1152), port 58175 | Closed. | 2017-10-04 06:16:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:16:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58175 | 2017-10-04 06:16:57
DTC Client (98) | Creating socket. | 2017-10-04 06:16:58
DTC Client (98) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:16:58
Rithmic Trading | Connected to server. | 2017-10-04 06:16:58
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:16:58
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:16:58
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:16:58
Rithmic Trading | Sending logon request message. | 2017-10-04 06:16:58
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:16:58
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:16:58
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:16:58
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:16:59
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:17:00
Rithmic Trading | Received logon response. | 2017-10-04 06:17:00
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:17:00
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:17:00
Rithmic Trading | Logon error received from server | 2017-10-04 06:17:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:17:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:17:00
DTC Client (98) | Initiating close of socket by core. | 2017-10-04 06:17:00
DTC Client (98) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:17:00
DTC Client (98) | Socket gracefully closed by remote side. | 2017-10-04 06:17:00
DTC Client (98) | Closed. | 2017-10-04 06:17:00
Rithmic Trading | Disconnected. | 2017-10-04 06:17:00
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:17:00
Rithmic Trading | Port for executable: 58189 | 2017-10-04 06:19:00
Listening socket (1168), port 58189 | Closed. | 2017-10-04 06:19:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:19:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58189 | 2017-10-04 06:19:02
DTC Client (100) | Creating socket. | 2017-10-04 06:19:02
DTC Client (100) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:19:02
Rithmic Trading | Connected to server. | 2017-10-04 06:19:02
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:19:02
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:19:02
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:19:02
Rithmic Trading | Sending logon request message. | 2017-10-04 06:19:02
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:19:02
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:19:02
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:19:02
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:19:03
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:19:04
Rithmic Trading | Received logon response. | 2017-10-04 06:19:04
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:19:04
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:19:04
Rithmic Trading | Logon error received from server | 2017-10-04 06:19:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:19:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:19:04
DTC Client (100) | Initiating close of socket by core. | 2017-10-04 06:19:04
DTC Client (100) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:19:04
DTC Client (100) | Socket gracefully closed by remote side. | 2017-10-04 06:19:04
Rithmic Trading | Disconnected. | 2017-10-04 06:19:04
DTC Client (100) | Closed. | 2017-10-04 06:19:04
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:19:04
Rithmic Trading | Port for executable: 58203 | 2017-10-04 06:21:04
Listening socket (1048), port 58203 | Closed. | 2017-10-04 06:21:04
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:21:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58203 | 2017-10-04 06:21:06
DTC Client (101) | Creating socket. | 2017-10-04 06:21:06
DTC Client (101) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:21:06
Rithmic Trading | Connected to server. | 2017-10-04 06:21:06
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:21:06
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:21:06
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:21:06
Rithmic Trading | Sending logon request message. | 2017-10-04 06:21:06
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:21:06
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:21:06
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:21:06
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:21:08
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:21:08
Rithmic Trading | Received logon response. | 2017-10-04 06:21:08
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:21:08
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:21:08
Rithmic Trading | Logon error received from server | 2017-10-04 06:21:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:21:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:21:08
DTC Client (101) | Initiating close of socket by core. | 2017-10-04 06:21:08
DTC Client (101) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:21:08
DTC Client (101) | Socket gracefully closed by remote side. | 2017-10-04 06:21:08
Rithmic Trading | Disconnected. | 2017-10-04 06:21:08
DTC Client (101) | Closed. | 2017-10-04 06:21:08
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:21:08
Rithmic Trading | Port for executable: 58217 | 2017-10-04 06:23:08
Listening socket (1072), port 58217 | Closed. | 2017-10-04 06:23:08
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:23:08
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58217 | 2017-10-04 06:23:10
DTC Client (102) | Creating socket. | 2017-10-04 06:23:10
DTC Client (102) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:23:10
Rithmic Trading | Connected to server. | 2017-10-04 06:23:10
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:23:10
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:23:10
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:23:10
Rithmic Trading | Sending logon request message. | 2017-10-04 06:23:10
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:23:10
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:23:10
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:23:10
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:23:11
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:23:11
Rithmic Trading | Received logon response. | 2017-10-04 06:23:11
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:23:11
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:23:11
Rithmic Trading | Logon error received from server | 2017-10-04 06:23:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:23:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:23:11
DTC Client (102) | Initiating close of socket by core. | 2017-10-04 06:23:11
Rithmic Trading | Disconnected. | 2017-10-04 06:23:11
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:23:11
DTC Client (102) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:23:11
DTC Client (102) | Socket gracefully closed by remote side. | 2017-10-04 06:23:11
DTC Client (102) | Closed. | 2017-10-04 06:23:11
Rithmic Trading | Port for executable: 58232 | 2017-10-04 06:25:11
Listening socket (1088), port 58232 | Closed. | 2017-10-04 06:25:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:25:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58232 | 2017-10-04 06:25:13
DTC Client (104) | Creating socket. | 2017-10-04 06:25:13
DTC Client (104) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:25:13
Rithmic Trading | Connected to server. | 2017-10-04 06:25:13
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:25:13
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:25:13
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:25:13
Rithmic Trading | Sending logon request message. | 2017-10-04 06:25:13
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:25:13
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:25:13
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:25:13
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:25:15
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:25:15
Rithmic Trading | Received logon response. | 2017-10-04 06:25:15
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:25:15
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:25:15
Rithmic Trading | Logon error received from server | 2017-10-04 06:25:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:25:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:25:15
DTC Client (104) | Initiating close of socket by core. | 2017-10-04 06:25:15
DTC Client (104) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:25:15
DTC Client (104) | Socket gracefully closed by remote side. | 2017-10-04 06:25:15
DTC Client (104) | Closed. | 2017-10-04 06:25:15
Rithmic Trading | Disconnected. | 2017-10-04 06:25:15
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:25:15
Rithmic Trading | Port for executable: 58245 | 2017-10-04 06:27:15
Listening socket (888), port 58245 | Closed. | 2017-10-04 06:27:15
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:27:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58245 | 2017-10-04 06:27:17
DTC Client (105) | Creating socket. | 2017-10-04 06:27:17
DTC Client (105) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:27:17
Rithmic Trading | Connected to server. | 2017-10-04 06:27:17
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:27:17
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:27:17
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:27:17
Rithmic Trading | Sending logon request message. | 2017-10-04 06:27:17
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:27:17
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:27:17
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:27:17
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:27:18
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:27:19
Rithmic Trading | Received logon response. | 2017-10-04 06:27:19
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:27:19
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:27:19
Rithmic Trading | Logon error received from server | 2017-10-04 06:27:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:27:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:27:19
DTC Client (105) | Initiating close of socket by core. | 2017-10-04 06:27:19
Rithmic Trading | Disconnected. | 2017-10-04 06:27:19
DTC Client (105) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:27:19
DTC Client (105) | Socket gracefully closed by remote side. | 2017-10-04 06:27:19
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:27:19
DTC Client (105) | Closed. | 2017-10-04 06:27:19
Rithmic Trading | Port for executable: 58259 | 2017-10-04 06:29:19
Listening socket (1060), port 58259 | Closed. | 2017-10-04 06:29:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:29:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58259 | 2017-10-04 06:29:21
DTC Client (107) | Creating socket. | 2017-10-04 06:29:21
DTC Client (107) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:29:21
Rithmic Trading | Connected to server. | 2017-10-04 06:29:21
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:29:21
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:29:21
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:29:21
Rithmic Trading | Sending logon request message. | 2017-10-04 06:29:21
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:29:21
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:29:21
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:29:21
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:29:22
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:29:22
Rithmic Trading | Received logon response. | 2017-10-04 06:29:22
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:29:22
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:29:22
Rithmic Trading | Logon error received from server | 2017-10-04 06:29:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:29:22
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:29:22
DTC Client (107) | Initiating close of socket by core. | 2017-10-04 06:29:22
DTC Client (107) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:29:22
DTC Client (107) | Socket gracefully closed by remote side. | 2017-10-04 06:29:22
DTC Client (107) | Closed. | 2017-10-04 06:29:22
Rithmic Trading | Disconnected. | 2017-10-04 06:29:22
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:29:22
Rithmic Trading | Port for executable: 58306 | 2017-10-04 06:31:22
Listening socket (1160), port 58306 | Closed. | 2017-10-04 06:31:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-10-04 06:31:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58306 | 2017-10-04 06:31:24
DTC Client (108) | Creating socket. | 2017-10-04 06:31:24
DTC Client (108) | Connecting to IP: 127.0.0.1. | 2017-10-04 06:31:24
Rithmic Trading | Connected to server. | 2017-10-04 06:31:24
Rithmic Trading | Starting socket receive thread. | 2017-10-04 06:31:24
Rithmic Trading | Sending Encoding Request to server | 2017-10-04 06:31:24
Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-10-04 06:31:24
Rithmic Trading | Sending logon request message. | 2017-10-04 06:31:24
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-10-04 06:31:24
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-10-04 06:31:24
Rithmic Trading | Message from server: Connecting to Rithmic MES Capital-Chicago server. | 2017-10-04 06:31:24
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-10-04 06:31:26
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2017-10-04 06:31:26
Rithmic Trading | Received logon response. | 2017-10-04 06:31:26
Rithmic Trading | Server Name: DTC Bridge. | 2017-10-04 06:31:26
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2017-10-04 06:31:26
Rithmic Trading | Logon error received from server | 2017-10-04 06:31:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-10-04 06:31:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2017-10-04 06:31:26
DTC Client (108) | Initiating close of socket by core. | 2017-10-04 06:31:26
DTC Client (108) | Shutdown started. Waiting for graceful close. | 2017-10-04 06:31:26
DTC Client (108) | Socket gracefully closed by remote side. | 2017-10-04 06:31:26
DTC Client (108) | Closed. | 2017-10-04 06:31:26
Rithmic Trading | Disconnected. | 2017-10-04 06:31:26
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-04 06:31:26
[2017-10-04 10:40:07]
Is it your intention to be connecting to this server?:
You are receiving a Permission Denied error:
Refer to this section for help with this:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
Date Time Of Last Edit: 2017-10-04 10:40:35
