Date/Time: Thu, 16 Jan 2025 00:55:16 +0000
Mexican Peso Futures Chart (Daily) display issue
View Count: 812
[2017-10-03 17:26:39] |
User134590 - Posts: 12 |
Sierra, Please view the uploaded image of the Mexican Peso Dec 17 Futures Daily Chart - I am using SC Real Time and Exchange Data with CTS FIX (ver 1615) This only happens on the daily,weekly chart- 4hr, 6hr, 8hr 12hr all display fine When you manually type 1d, or use control bar and select daily, or weekly this is the result - With or without it being a continuous contract - have reloaded, reset scale etc... For some reason the last bar is using the entire length of scale thus crushing all previous bars - Thanks http://www.sierrachart.com/image.php?Image=1507050316929.png |
[2017-10-03 18:27:14] |
This is now resolved. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
