Date/Time: Sun, 24 Nov 2024 03:00:03 +0000
compiler
View Count: 1254
[2013-09-09 00:57:12] |
M5amhan - Posts: 468 |
how do I uninstall the compiler? thanks |
[2013-09-09 02:27:40] |
You need to delete this folder: Drive:\Sierrachart\CPPcompiler Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
