Date/Time: Thu, 16 Jan 2025 01:10:14 +0000
Commission
View Count: 1356
[2017-10-03 17:12:01] |
Deltareversal - Posts: 46 |
In trade Activity not apper Commision. Where can I place the commissions I pay ? |
[2017-10-03 17:41:34] |
Xfanman1 - Posts: 320 |
Set up your commissions in Global Settings/Symbol Settings (see my attached image). You can set up individual commissions for each product you trade here. Global Symbol Settings |
Commission Settings.PNG / V - Attached On 2017-10-03 17:41:25 UTC - Size: 35.56 KB - 388 views |
[2017-10-03 18:29:20] |
Here is the documentation for using commissions on the Trade Activity Log: Trade Activity Log: Use Commission Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
