Date/Time: Thu, 16 Jan 2025 01:10:59 +0000
Live regression analysis in Sierra Chart Spreadsheets
View Count: 1195
[2017-10-03 16:00:06] |
User606491 - Posts: 164 |
I want to perform regression analysis on live data. As far as I am aware, SC's spreadsheets do not automatically calculate regressions (least squares, etc.). How do you recommend I overcome this? Is there a way to transfer live data into a program like Stata, R, or Solver, then reintroduce it into the SC spreadsheet to execute trades?
[2017-10-03 17:10:08] |
What particular Spreadsheet functions did you require for this? The supported functions are here: Spreadsheet Functions We can add additional functions as needed. Is there a way to transfer live data into a program like Stata, R, or Solver, then reintroduce it into the SC spreadsheet to execute trades? Know, this is not possible and would have problems and not be efficient.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-03 17:10:39
