Date/Time: Thu, 16 Jan 2025 01:11:56 +0000
TPO Charts
View Count: 1120
[2017-10-03 15:44:59] |
User133414 - Posts: 1 |
Hello, When I load TPO Charts, the letters are crushed together and not visible. Please see attached image. It seems it is more of an issue with the scale of the Y axis rather than the TPO Chart itself. Thanks! |
screen12.PNG / V - Attached On 2017-10-03 15:41:05 UTC - Size: 32.4 KB - 334 views Attachment Deleted. |
[2017-10-03 17:46:15] |
How to solve this is explained here: https://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#DisplayIssues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
