Date/Time: Thu, 16 Jan 2025 06:42:51 +0000
Deleting/Recreating Instances
View Count: 1625
[2017-10-03 14:40:51] |
samual sprat - Posts: 343 |
Hi, My installation of SC has 2 additional instances with their own data folders. I created the 2 instances to test out the functionality when I first installed SC. I've since made a bunch of changes to my main installation along with creating various study collections. What i'd like to do is delete both instances and recreate them. My understanding is that when you first create an instance it automatically copies across all the data and settings, is that right? So creating the instances again will copy across all current settings/data etc from the main data folder which is what i'd like to do ideally. Is this okay to do? What should I delete? Thanks for you help Sunny |
[2017-10-03 18:41:07] |
My understanding is that when you first create an instance it automatically copies across all the data and settings, is that right? Yes this is true.You just need to delete the SierraChartInstance_# folders within the main Sierra Chart folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-03 18:56:05] |
Here is the relevant documentation: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Deleting Sub Instances Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-11 10:31:28] |
Hi. Just to add to this discussion. I'm currently syncing files between instances to get them all aligned. I'm following the documentation here but it's for separate installations, not instances: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Is it safe to copy the sierra3.cfg from main install to instance folders? Seems that it may conflict as the data folder locations may be stored in there? Can't find any documentation on this, but is it safe to sync the following configs: Sierra3.cfg GlobalSymbolSettings.xml KeyBoardShortcuts.config MenuCustomisations.xml SCStudiesDefSettings.ini Thanks S |
[2017-10-11 17:11:11] |
Yes, it is safe to copy those files over to a sub instance. Make sure no copies of Sierra Chart are running when you do this. And in the sub instances, make sure this option is enabled: General Settings Window: Always Use 'Data' Folder within Main Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-11 17:17:54] |
Awesome. Thanks so much for your help
[2017-10-21 09:42:50] |
Hi, Since setting up multiple instances with the "Always Use 'Data' Folder within Main Folder" option enabled, my instances are not being updated when I update the master version (exe from the main folder). Searched but no luck. Any idea why this may happen? Thanks S |
[2017-10-21 10:33:58] |
They will be updated as soon as you exit them and start them again from the main instance using File >> New Instance.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-21 10:34:10
