Date/Time: Thu, 16 Jan 2025 00:48:33 +0000
Calculation of a moving average that is recalculated after fixed time periods
View Count: 854
[2017-10-03 12:50:31] |
equinox - Posts: 11 |
The bar period of my main chart is 1 month.I would like to plot the price average of the 3 past years for every 3-quarter time period on this chart, e.g. the average line would change every 3 quarters for a new calculation of the average of the last 3 year period. This results in horizontal "stair step" lines that change after each 3-quarter period (in contrast to a conventional moving average, which updates the calculation after each bar). Just to try if I could get a result close to what I am looking for, I constructed a source graph with a bar period of 3 quarters and a simple moving average of 12 bars (3 years), and overlaid this study to my target graph (monthly bars). However, in the source graph, it seems I cannot specify 3 quarters as one bar under chart settings. I hope I could make myself understood, any ideas appreciated. |
[2017-10-03 18:10:16] |
You can specify the Historical chart a bar period using a number of Days but not a number of quarters. Refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysHistoricalCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-03 18:11:00
[2017-10-03 21:19:41] |
Thank you, this worked!
