Date/Time: Thu, 16 Jan 2025 09:44:14 +0000
LMax market Depth
View Count: 1315
[2017-10-03 10:16:25] |
User78442 - Posts: 260 |
Hi, I want to use Lmax's market depth but they provide data every 0.1 PIP, is there any way I can aggregate the data to only display total depth per PIP?
[2017-10-03 14:51:23] |
We are going to be adding this capability.
[2017-10-03 17:12:09] |
Any timescale, Revision number?
[2017-10-03 17:37:36] |
We hope this will be done before the end of the year. That is about all we can say.
[2017-10-26 08:36:25] |
AlexPereira - Posts: 197 |
Is this the feature: "Market Depth Combine Increment in Ticks" ? It seems to be. Confirm ? ( I missed any news or documentation about this ) |
[2017-10-26 08:42:05] |
Yes it is.
[2017-10-26 10:04:52] |
Please advise if this is available and in what version and where it can be configured.
[2017-10-26 12:22:18] |
You can configure it on the symbol settings of each symbol ( last tab ) or You can set it on the "Chart settings", "Advances settings 3". |
[2017-10-26 13:09:26] |
Sorted after loading Ver 1629
[2017-10-26 17:59:59] |
The Market Depth Data Price Combine Increment setting in the Global Symbol Settings at this time is not implemented and does nothing.
