Date/Time: Thu, 16 Jan 2025 00:49:43 +0000
Volume by Price Study-cannot change tick per volume bar
View Count: 933
[2017-10-03 01:29:13] |
vectorTrader - Posts: 86 |
I am using a intraday chart and trying to load last weeks data at 2 ticks per volume bar but I only get 5. Is this a new standard setting?
[2017-10-03 03:37:21] |
No. You need to adjust the Volume at Price Multiplier to 1 as explained here: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-03 03:37:33
