Date/Time: Tue, 25 Feb 2025 22:06:14 +0000
Is it possible to remove Flatten & Reverse buttons from TradeDOM?
View Count: 1933
[2013-09-08 13:48:02] |
FLfutures - Posts: 11 |
Too easy to click on Reverse, or Flatten, within TraderDom. Can the buttons be removed? Thanks. |
[2013-09-08 15:45:13] |
skoosht - Posts: 13 |
under "Trade", "chart trade settings" there's a "trade window controls" section of check boxes. Unchecking those entries will disable the buttons. |
[2013-09-08 20:25:28] |
These buttons can be disabled through Trade >> Chart Trade Settings. If you update to the latest version of Sierra Chart, changes will be immediately applied. Otherwise, you need to close and reopen the trade window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-03 04:06:03] |
User656492 - Posts: 146 |
I'd like to REMOVE the reverse button, not just disable it. Is this possible?
[2021-05-03 08:29:04] |
Sierra_Chart Engineering - Posts: 18565 |
Not at this time. We hope to offer that before the end of the year but it will be a long time.
