Date/Time: Thu, 16 Jan 2025 01:07:36 +0000
USDCAD from FXCM not updating
View Count: 840
[2017-10-02 19:09:53]
phaedonk - Posts: 352
For almost 4 hours now, manually downloading data does not work either. Can you check this please? Not sure if it's happening with other FX pairs too.
[2017-10-02 22:09:43]
Make sure you are using the correct symbol which is USDCAD and follow the instructions (3.14) here to update the Symbol Settings:
https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.14
If that is not relevant help topic, refer to the other ones on that page.
Also the data feed for this symbol is fine.
Date Time Of Last Edit: 2017-10-02 22:09:58
