Date/Time: Thu, 16 Jan 2025 01:07:53 +0000
Two trading account
View Count: 736
[2017-10-02 17:20:43] |
Deltareversal - Posts: 46 |
I have two trading account with the same broker, it's possible to send in the same time the order in two different account ? Regards |
[2017-10-02 17:42:44] |
No, this is not supported. If both of those accounts are on the same username that you use to connect to the Trading service, you can select among them. Refer to: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
