Date/Time: Thu, 16 Jan 2025 00:51:07 +0000
Numbers Bars - printing
View Count: 1396
[2017-10-02 15:51:19]
User40526 - Posts: 166
Recently I have been unable to print legible numbers bars. The font, which I have not changed since setting up the numbers bars, is set to 7 and appears to be too large I never had this problem before and I am unable to determine what I can do to remedy the problem. I can print the bars with the font set to 0 but don't understand why I was able to print with font of 7 in the past and now can't do so. I downloaded the current version today and that did not solve the problem. Thank you
[2017-10-02 17:36:27]
This is what we see when using a Font Size of 7:
http://www.sierrachart.com/image.php?Image=1506965744944.png
We would not expect any problem with this.
Provide an image of the chart or Trade DOM, by following these instructions:
[2017-10-02 18:03:24]
I am responding to your request to provide an image of the chart. The image is fine. The problem is with printing it legibly which is a new problem I have not had before. Thank you
http://www.sierrachart.com/image.php?Image=1506967231493.png
[2017-10-03 09:22:14]
OK we understand the problem and we now have this resolved. We will have a new release out later today.
[2017-10-04 16:49:36]
Thank you for trying but it didn't change the outcome. I am using #7 font and the numbers bars print massive numbers which, of course, don't show up. Please advise. Thank you.
It prints legibly using 0 for the font, but then it's too big when printed to get more than a fraction of the page. This is why I went to a smaller font a couple of years ago to print numbers bars. Thank you.
Date Time Of Last Edit: 2017-10-04 16:52:46
[2017-10-04 17:38:33]
Update Sierra Chart following these instructions:
We are sure the problem is resolved. We did a test.
[2017-10-04 18:35:50]
Thank you. I did a Download Current Version last night and got version 1619 (had 1617 already) so I figured that was the update. When it printed the same today I tried another download and it said I had the current version. After sending you the follow up, I tried again just now and it downloaded version 1620. Fixed. Thank you!
