Date/Time: Thu, 16 Jan 2025 01:02:07 +0000
data for NASDAQ
View Count: 1075
[2017-10-02 14:43:15] |
User886298 - Posts: 2 |
I will only have one connection. I will be using Interactive Brokers to trade, but I hate their data. I need to be able to see real time data on any symbol on the NASDAQ. I only need 100 symbols maximum active in any one day, but the list will need to change from day-to-day. I cannot be limited to a single list of 100 pre-defined symbols. What is the price if I purchase unlimited real time NASDAQ data from Sierra Charts, with market depth? What is the price if I purchase unlimited real time NASDAQ data from Sierra Charts, without market depth? Should I use a third party vendor to provide data instead of Sierra Charts data? If yes, whom do you recommend? |
[2017-10-02 17:11:24] |
We recommend using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed In the case of NASDAQ, there is no market depth data provided. Pricing can be found on that page. You will need to activate the US Equities exchange as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
