Date/Time: Thu, 16 Jan 2025 00:50:58 +0000
Histogram for 1st 15 minutes of the RTH compared to 20 prior days RTH...
View Count: 909
[2017-10-02 13:36:08]
User629089 - Posts: 93
I would like to set up a histogram for the 1st 15 minutes of the RTH session for comparison to the prior 20 days median/average volume for that same 15 minute timeframe. If possible, without any other data than that 1st 15 minutes for easy comparison...
Thanks...
[2017-10-02 17:28:41]
You can use the Relative Volume study for this:
Relative Volume
But it is going to perform calculations on more than just the first 15 minutes. It is possible to limit it though to the Day session. So if you set the Session Times so the Day Session (non Evening session times) is just 15 minutes, that would be a solution. Refer to:
Chart Session Times
