Date/Time: Thu, 16 Jan 2025 01:13:10 +0000
Cursor synchronization
View Count: 1534
[2017-10-01 20:20:43] |
SPTrader - Posts: 4 |
Is it possible to customize the tool values window? Can you make the region data line display values at the current cursor instead of the last displayed value? |
[2017-10-01 20:26:06] |
Yes of course. This is explained in detail here: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools There are various subsections in that section. Be sure to go through all of them. This whole subject is well-documented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-02 16:45:28] |
I still cannot figure out how to get the region data line or what I suppose is the study data line to synchronize with the cursor or the 'Tool Values Window'. Thanks |
[2017-10-02 17:17:51] |
Can you make the region data line display values at the current cursor instead of the last displayed value? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
