Date/Time: Thu, 16 Jan 2025 00:00:05 +0000
Sierra Default Config Files for Rapid Deployment
View Count: 879
[2017-10-01 17:48:51] |
MichaelPPTF - Posts: 69 |
Hello Support Staff, I am an educator and I have some charts, chartbooks, and global graphics settings to be shared with my members. Sharing charts and chartbooks are easy, however, I can't seem to find a global config file to share my graphics(background, text color), time, technical tools settings. So it came to a point where I would like to share the entire Sierra folder but don't know which folder or file contains my login credentials so I can leave it out. Any suggestions? I know I have asked lots of questions here, and my account appears to be a free expired one, but I am a paid user with Infinity and I just don't know how to login with Infinity's credentials. |
[2017-10-01 20:28:34] |
You need to provide the Sierra3.cfg file to them. It is fine to post questions with this account. Sierra Chart does have the ability to automatically distribute a Sierra3.cfg file to users authorized for a particular group of custom studies. Even if you do not use custom studies, this feature can still be used for this purpose. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
