Date/Time: Thu, 16 Jan 2025 00:08:05 +0000
Different Data Based on Zoom or Scroll
View Count: 1064
[2017-10-01 12:46:56] |
User172040 - Posts: 70 |
Hi, I am using Cum Delta - Volume as a secondary indicator and I also plot a 10 Mov Avg of this Cum Delta on the secondary indicator. However, I have found that the Cum Delta vs MA relationship will differ depending on the zoom or scroll of the chart. In other words, at exactly the same time, the Cumulative Delta may be above or below the MA dependent on the zoom or scroll of the chart. A lot of my decisions are based on accurate visual display of this relationship. Please see attached 2 examples as well as my settings. I also tried a setting of 'Independent' on my 10 MA Scale Range but the results stay the same. If we look at the price of a chart (tick chart) and its relationship with a MA, the relationship is constant. It does not change based on scroll or zoom. How do I fix this issue? |
CD above MA.PNG / V - Attached On 2017-10-01 12:46:08 UTC - Size: 66.19 KB - 253 views CD under MA.PNG / V - Attached On 2017-10-01 12:46:29 UTC - Size: 67.67 KB - 260 views CD MA Settings.PNG / V - Attached On 2017-10-01 12:46:34 UTC - Size: 54.97 KB - 259 views |
[2017-10-01 19:43:50] |
Also make sure the Scale Range for Cumulative Delta Bars-Volume is set to Automatic.
