Date/Time: Wed, 15 Jan 2025 23:55:48 +0000
About Pivot Point R6 and S6 lines and values position
View Count: 1129
[2017-10-01 07:49:31] |
User513952 - Posts: 84 |
Hi, The position R6 and S6 lines and values of Pivot point study (Formula Type=24) cannot be aligned to the left as other lines (R1,S1...R5,S5). Please advise. Thanks Charlie |
Piviot Point.JPG / V - Attached On 2017-10-01 07:47:02 UTC - Size: 216.87 KB - 308 views Piviot Point2.JPG / V - Attached On 2017-10-01 07:48:49 UTC - Size: 76.39 KB - 264 views Piviot Point3.JPG / V - Attached On 2017-10-01 07:48:54 UTC - Size: 107.53 KB - 275 views |
[2017-10-01 19:32:15] |
This will be solved in the next release.
