Date/Time: Wed, 15 Jan 2025 23:47:57 +0000
Replay Control Panel
View Count: 1152
[2017-09-30 23:51:33]
User82486 - Posts: 43
I HAVE BEEN USING sc FOR YEARS AND MANY TIMES HAVE USED THE REPLAY chart PROGRAM EITHER WITH cTRLR OE WITH THWE DROPDOWQN ENTRY IN "CCHARTS"
tODAY I USED AGAIN AND DURING THE DAY I NO LONGER AM ABLE TO ACTIVAATE IT OR EVEN FIND IT HIDDEN BEHIND A GRAPH I HAVE A SECOND INSTANCE OF SC AND IT WORKS FINE ON THAT (TD AMERITRADE) BUT ON THE AMP DATA FEED NO LUCK.
WHAT AM I DOING WRONG?
FRED
[2017-10-01 00:19:15]
Select Window >> Reset Windows to reset the position of the replay control panel. After that try opening it again.
