Date/Time: Wed, 15 Jan 2025 23:53:04 +0000
Text Tool - issue
View Count: 1406
[2017-09-30 22:42:52] |
Marek F - Posts: 244 |
I'm not sure is it any issue: 1) I set in the Text Properties --> Options --> Font (Select) any font, and OK. There is visible a name of this font next to the button "Select". 2) When you close the Text Properties window and reopen it, the font name disappears. If i want change this text to Italic, then first i have to again select type of the font. Otherwise there is not any change. Issue above do not occur if i set "Configure Button" of the Text Tool. Every settings are saved. Next issue is that i can't change type of the font. No matter what you choose, it is always the same type of font. I have Windows 8.1 |
Text Tool.png / V - Attached On 2017-09-30 22:42:02 UTC - Size: 26.76 KB - 365 views |
[2017-10-01 00:16:54] |
We see a problem with this. Will fix. This might also explain some other font related issues.
[2017-10-01 02:36:49] |
We have this now fixed. We are putting out a release in about 30 minutes.
