Date/Time: Thu, 16 Jan 2025 00:17:57 +0000
sc.ValueFormat = 40???
View Count: 1008
[2017-09-30 15:22:35] |
@sstfrederik - Posts: 405 |
HI, I have a custom study with sc.GraphRegion = 0; in the defaults block. The sc.ValueFormat should than be inherited from the chart settings. When I use sc.ValueFormat later to format a string I find that sc.Valueformat equals 40 while I expect 5. Any pointers to what I might have missed? Frederik edit: used sc.BaseGraphValueFormat instead. All fine for my use case. Date Time Of Last Edit: 2017-09-30 15:57:22
[2017-09-30 22:49:12] |
This is from SCConstants.h: VALUEFORMAT_INHERITED = 40 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
