Date/Time: Thu, 16 Jan 2025 00:21:16 +0000
Is there a study for ratio with 2 instruments not on original chart?
View Count: 1150
[2017-09-30 15:01:05] |
User953894 - Posts: 58 |
I couldn't find a study that does this so I created 2 overlays on my chart then did the Study Subgraphs Divide/Ratio study. This works, but it involves 2 extra steps.
[2017-10-01 02:51:29] |
Yes this can be done with the Ratio study: Ratio (Bar) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-01 15:37:31] |
I have used the Ratio study several times in the past. But it only allows entry of 1 chart and compares against the current chart. I'm looking for a study that allows the ratio of 2 instruments that can be mapped on the chart of a 3rd instrument. I've used 3 chart spread to print the difference of 2 charts on a 3rd chart, but for this I require the ratio, not the difference. Thanks in advance! |
