Date/Time: Thu, 16 Jan 2025 05:48:25 +0000
TPO Charts - Scrolling back
View Count: 2453
[2017-09-30 08:51:48] |
User995923 - Posts: 64 |
Hello Is there any way to change how scrolling back works on a chart? For example it currently moves up or down depending on the location of the prices. Is it possible to scroll back while staying still (no up or down so ignoring prices)? Regards Date Time Of Last Edit: 2017-09-30 09:48:04
[2017-10-01 20:37:32] |
Update to the current version of Sierra Chart following these instructions here: Software Download: Fast Update For what you want to do, right-click on the Values Scale on the right side of the chart and select Scale Range: User Defined with Auto Set. This will lock the scale to what you currently see. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-02 02:29:18] |
Although it works on normal bar charts, when I tried applying it on TPO charts it did not work. As soon as I apply Scale Range: User Defined with Auto Set the chart becomes blank. Regards |
GBPCAD [CB] [M] #7 2017-10-02 05_27_42.807.png / V - Attached On 2017-10-02 02:28:51 UTC - Size: 140.01 KB - 330 views GBPCAD [CB] [M] #7 2017-10-02 05_27_51.761.png / V - Attached On 2017-10-02 02:28:58 UTC - Size: 21.32 KB - 316 views |
[2017-10-02 03:31:39] |
Actually, this could be. TPO charts are special in the way that they are scaled. We really do not have time to research this now.
[2017-10-02 05:05:01] |
We have this problem solved. It was a very simple solution. This will be out in the next release.
[2017-10-02 16:37:05] |
This is now out in prerelease version 1618.
[2017-10-12 04:30:52] |
Hello I downloaded today the prerelease version 1622 and it still doesn't work. Can you please confirm it is fixed? I right click on the right scale of a TPO chart, choose Scale range: User defined with Autoset and the chart still becomes blank. Regards |
[2017-10-12 04:52:36] |
We verified now that it does work properly. No problem at all. Are there any other studies on the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-12 05:24:55] |
Volume by price - VbP for TPO Chart Current Price Line |
[2017-10-12 06:44:22] |
If I create a a new fresh TPO study it works. I will find why my old customized one does not work by creating a new and testing each option I change and I will see which option causes the problem and report. Regards |
[2017-10-12 08:55:21] |
OK but we can test this if we get the chart from you. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-12 09:23:02] |
I have attached the chartbook Regards |
TPO.cht - Attached On 2017-10-12 09:22:33 UTC - Size: 54.49 KB - 374 views |
[2017-10-15 02:01:34] |
This is now corrected. We will be having a new release out in about an hour.
