Date/Time: Wed, 15 Jan 2025 23:51:54 +0000
.05 cent spread stocks need tick size changed in IB?
View Count: 759
[2017-09-29 20:59:20] |
Robert D - Posts: 24 |
Is this true? Does the tick size only need to be changed in---- chart--chart settings--tick size. Thank you |
[2017-09-29 21:40:52] |
If that is the price increment for a particular stock, it is sufficient just to change the Tick Size in the Chart >> Settings. To find out what it actually is, check with the Interactive Brokers symbol specifications for the particular symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-29 21:42:07
