Date/Time: Thu, 16 Jan 2025 00:19:59 +0000
connectivity problems with cqg
View Count: 1178
[2017-09-29 17:45:46] |
User541842 - Posts: 34 |
hi there, since yesterday i have permanent connectivity problems with cqg. i will send the log in a few moments. technical support from amp futures was not very helpful in this case. hope you can point me in the right direction. thanks in advance |
[2017-09-29 18:08:00] |
This is one of the relevant messages: CQG WebSocket socket (113) | Connect event error. Windows error code 10060: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. | 2017-09-29 19:43:49 * All we can say is there is a connectivity problem between Sierra Chart on your computer and the CQG server. Where the problem is we do not know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
