Date/Time: Thu, 16 Jan 2025 00:10:56 +0000
Time and sales audible alert in settings repeat instead of only sounding once.
View Count: 1138
[2017-09-29 15:35:09] |
User45158 - Posts: 31 |
Time and sales audible alert in settings repeat instead of only sounding once, settings are correct per instruction but repetition exists still
[2017-09-29 18:11:04] |
In the Alerts Log: http://www.sierrachart.com/index.php?page=doc/AlertsManager.html Do you see a separate message for each alert sound? If you are running other instances of Sierra Chart or have other instances of Time and Sales windows, those can generate Time and Sales alerts you have configured as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
