Date/Time: Thu, 16 Jan 2025 00:05:26 +0000
Settlement Price Study
View Count: 2663
[2017-09-29 09:38:01] |
traderacademie - Posts: 38 |
Hi, Is there a study for the settlement price of an instrument? Or how can I otherwise display it? Rgds Will |
[2017-09-29 09:54:55] |
infpz - Posts: 826 |
Hi Will, Daily bars use the settlement as the close. So if need be, I will display the Daily OHLC study to a Daily Chart, hide all the lines except the Close, and then use Study/Price Overlay to over the result onto whatever other chart I want to use. Hope this helps, feel free to email me more questions. pz@infinityfutures.com |
[2017-09-29 10:27:09] |
Thanks, It is also described in another ticket Settlement |
[2017-09-29 10:31:13] |
it works well. good luck. PZ
[2017-09-29 17:22:44] |
Settlement prices can be viewed through Historical Daily charts: http://www.sierrachart.com/index.php?page=doc/GettingStarted.php#OpenChart Also refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails12.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
