Date/Time: Thu, 16 Jan 2025 00:22:40 +0000
How to overaly 2+ different assets
View Count: 1109
[2017-09-29 08:42:00] |
Fabio - Posts: 117 |
Good morning, I am writing you because I tried different studies but I can't get the right solution; I would like to compare 2 or more securities on the same chart (i.e. to see some possible correlation). The closest study is "Add additional symbol" and then move it into chart region 1 as the main price graph, but the problem is that the assets work on different price scale and I can't compare those unless "scrunching" the chart. Which tools can I use in order to "free" the price scale from both assets and have a look just to the "general movement" during a period of time? Thanks, F. |
[2017-09-29 17:58:26] |
This is explained here: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#OverlayingMultipleSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
