Date/Time: Wed, 15 Jan 2025 23:48:57 +0000
Numbers Bars Calculated Values - High Low Range
View Count: 1893
[2017-09-29 06:56:10] |
User787778 - Posts: 142 |
There is a difference between in the value of ticks shown in the Numbers Bars Calculated Values - High Low Range and the Bar Difference study or the Chart Calculator. The Numbers Bars Calculated Values shows one tick more in each bar. |
[2017-09-29 18:33:58] |
We are aware of this and we will resolve it. Apparently we may have done this in response to another user request but we understand what you are saying.
