Date/Time: Tue, 22 Apr 2025 02:27:40 +0000
SGX iron ore data
View Count: 1655
[2017-09-29 06:55:31] |
User331240 - Posts: 1 |
Hi, I am trading iron ore on SGX(Singapore Exchange), I would like to try your chart system on Iron ore on SGX, but on the demo system I can not find SGX data feeding, how can I get SGX data feeding?
[2017-09-29 17:20:57] |
The available symbols are listed here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#SIMEX We need to add them to the symbol list in File >> Find Symbol. We will start with the iron ore ones. However, be aware that there is only end of day data available for this exchange. Do you need real-time data? If so, you should be able to obtain it through the supported Interactive Brokers trading service: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-04 05:08:34] |
We have added all of the available SGX symbols in File >> Find Symbol. You can find the iron ore ones in File >> Find Symbol >> Futures - Metals. We have also reset the trial on your account. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-04 05:08:58
