Date/Time: Wed, 15 Jan 2025 23:51:54 +0000
P&F chart reversal marker
View Count: 1358
[2017-09-28 22:45:50] |
N!co - Posts: 140 |
Hi, i am using a 1 min. chart with the Point & Figure chart study applied to i am using the study insted of just setting the chart to P&F because i want to use Box size percentage as box size Could it be that the "Point and Figure chart Reversal Marker" study does not work on a chart that has the Point and Figure study applied to ? or i am i doing something wrong thank you very much |
[2017-09-29 02:26:03] |
We did confirm that the "Point and Figure chart Reversal Marker" study does only work with the Point and Figure Bar setting in Chart >> Chart Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-29 02:26:12
