Date/Time: Thu, 16 Jan 2025 01:14:39 +0000
Looked around but not found answers to a couple of questions. Thanks :)
View Count: 1137
[2017-09-28 22:40:46]
samual sprat - Posts: 343
- can I use SMS price alerts from the UK? Tested with +44xxxxxx but didn't work
- Can you reference study outputs across chart books? e.g. Use price of an MA from a chart in chartbook A, on a chart in chartbook B?
- Can you save chart settings globally or create a save as default? I'm having to save the chart settings individually atm, which is fine, but just time consuming
- Can you configure studies to only appear on certain timeframes?
- can I load a GBPUSD chart up (non futures) and overlay futures level 1 volume data over the top? I don't think this is possible from my tests
- Can I run >2 instances and all share the same data folder to save copying files around the filesystem or would this create an issue with saves/updates becoming out of sync?
- Is it possible to use the 'Divergence Detector' study to find hidden divergences? i can only seem to find normal divergence?
Thanks,
Sunny
[2017-09-29 17:08:12]
1. We need to know the SMS error message you received in Window >> Alerts Manager >> Alerts Log. You can copy it and paste it here.
2. No.
3. Refer to:
http://www.sierrachart.com/index.php?page=doc/UsingChartTemplates.php
4. No.
5. Yes use this study:
http://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php
6.
Never do this! Do not even try!
Further help will require a paid account.
Date Time Of Last Edit: 2017-09-29 17:08:42
[2017-09-30 11:53:19]
Thanks. I will test out the SMS alert again when the market opens
Just subscribed ahead of my trial expiry, Sierra is well worth it
Any idea on the last question?
[2017-10-01 22:06:08]
It is not clear what is meant by hidden divergences.
The study is well documented here:
Divergence Detector
So it only functions according to how it is documented.
