Date/Time: Thu, 16 Jan 2025 00:07:42 +0000
Error msg on startup
View Count: 981
[2017-09-28 18:51:03] |
onnb - Posts: 662 |
I get this error message on startup. I have downloads disabled on my account so the msg makes sense. But not sure why it appears as an ERROR Error getting list of user files to download. Response: ERROR: Downloading of files on startup is disabled | HTTP status: Request completed with the HTTP response status code 200. | 2017-09-28 14:47:40 * |
[2017-09-28 19:05:10] |
We will make sure that message does not open the Message Log. With the way the code is designed, it is considered an error to the program. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
