Date/Time: Wed, 15 Jan 2025 23:47:24 +0000
ADR displayed on chart header
View Count: 987
[2017-09-28 11:11:30] |
grantx - Posts: 244 |
I use tick charts and I simply want to see the ADR or ATR value for the past X amount of days (Not based on bars - this is useless to me on tick charts). Displayed in the chart header if possible. How? |
[2017-09-28 18:36:20] |
These two studies are available: Average Daily Range Average True Range You can display these as text only by using this study: Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
