Date/Time: Wed, 15 Jan 2025 23:46:58 +0000
Trading DOM
View Count: 1141
[2017-09-28 10:40:09] |
Deltareversal - Posts: 46 |
I'm trying to set my DOM as attached picture (DOM), but I can not. Can you help me to set it in the same way. My Sierra chart is a Demo through Infinity Future. |
[2017-09-28 18:37:38] |
You need to use your own direct account for this. Refer to: Direct Sierra Chart Account Otherwise, this functionality is not available to you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-28 18:38:41
[2017-09-28 19:07:14] |
Thx. If I wanted to change from Sierra via Inifinity to SIERRA for fee, what I have to change to start. |
[2017-09-28 19:27:46] |
You just need to follow through the instructions here: Direct Sierra Chart Account The instructions are clear on what to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-28 19:44:56] |
Following the procedure that I find I lose all the setup. Example Control Bar
[2017-09-28 23:04:18] |
Follow the instructions here to copy the files: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Updating Existing Installation of Sierra Chart with Files and Settings from Another Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
