Date/Time: Thu, 16 Jan 2025 00:11:20 +0000
Setting background color for daily P/L in chart trade window?
View Count: 1545
[2017-09-28 10:14:42] |
User92081 - Posts: 4 |
Can you help me find out how to set the background color for the Daily P/L display in the chart trade window? Attached is a picture that shows the display I'd like to control outlined in red. I can set background color for Position and P/L display (outlined in green in the picture) from global settings/graphic settings-global/colors and widths. I can't figure out how to change the Daily P/L background, though. I would like to change it to the same background color as Position and P/L. I'm using version 1549. |
Daily profit-loss background color.png / V - Attached On 2017-09-28 10:10:48 UTC - Size: 5.24 KB - 413 views |
[2017-09-28 18:31:04] |
This can be done through the Graphics Settings window. Refer to: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM This is the relevant color setting: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trade Window Position Flat Background Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-28 18:32:54
