Date/Time: Wed, 15 Jan 2025 23:48:48 +0000
High or Low of the bar first ?
View Count: 882
[2017-09-28 08:17:24] |
buylosellhi - Posts: 60 |
Hi, Has anyone written anything in SC that can show if the High or Low of a given time based bar came first ? To do this right it should work off the underlying tick data. Thanks much ! |
[2017-09-28 09:34:41] |
There is nothing directly available the Sierra Chart custom study interface for a programmer to determine this. You really have to make reference to a shorter time frame bar to make this determination. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
