Date/Time: Thu, 16 Jan 2025 00:22:39 +0000
Order Types
View Count: 684
[2017-09-28 07:42:47] |
User681267 - Posts: 16 |
If you go to Trade >> Chart DOM Settings, how do you select a Buy-Stop-Limit or Sell-Stop-Limit order?
[2017-09-28 08:51:17] |
You need to update Sierra Chart to the current version to see these particular order types in the Chart DOM Settings window. Follow the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
