Date/Time: Thu, 16 Jan 2025 00:49:55 +0000
[User Discussion] - Start MA at beginning of day
View Count: 1088
[2017-09-28 00:56:35] |
Rino - Posts: 124 |
Hi, I have Tick overlayed on this chart. I want to put a moving average (As on snapshot) on the Tick part. How do I get the moving average to start at the beginning of session? Thanks as always |
[2017-10-02 17:12:46] |
Rino - Posts: 124 |
Hi, You may have missed me? When you get a minute. Thanks |
[2017-10-04 16:48:13] |
Rino - Posts: 124 |
[2017-10-04 18:40:59] |
The only way to do this is to set the Days to Load setting in Chart Settings to 1: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Also make sure the Overlay Study and the Moving Average study it is based on both have a Scale Range of Automatic: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-04 18:41:41
