Date/Time: Thu, 16 Jan 2025 00:09:00 +0000
cant open Sierra charts in Win10
View Count: 939
[2017-09-28 00:28:00] |
User397145 - Posts: 11 |
I downloaded Sierra Charts on my Win10 computer and I cannot get it to open or uninstall.
[2017-09-28 01:30:58] |
Go to the folder you installed Sierra Chart to on that computer. Run the SierraChart.exe file. What do you see appear? And go to the Windows Task Manager. Do you see Sierra Chart running in the Details list? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-28 08:24:35] |
I do not see the sierrachart.exe file, and it is not running in task manager
[2017-09-28 08:49:44] |
Therefore, install Sierra Chart again from this page: Software Download It sounds as though what has happened is that anti-malware software on your computer has deleted Sierra Chart for an unknown reason. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
