Date/Time: Mon, 05 Oct 2026 07:21:41 +0000
[Programming Help] - SC Function to find trade position
View Count: 1882
[2017-09-27 16:42:23]
User203925 - Posts: 40
Main objective is to have a strategy that has a triggered trailing stop to reverse when criteria are met.
Question 1:
Do I have to have sc.AllowMultipleEntriesInSameDirection set to true to make this happen?
Here is the code that launches my triggered trailing stop
if (sc.BaseData[SC_LAST][sc.Index - 1] < b_TradeTarget && sc.BaseData[SC_LAST][sc.Index] >= b_TradeTarget && ExistingOrder.Price1 != b_TrailStop) {
      b_TrailStop = b_TradeTarget - (TrailStopOff.GetInt() *sc.TickSize);
      NewOrder.OrderQuantity = OrderQuantity.GetInt();
      NewOrder.OrderType = SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_3_OFFSETS;
      NewOrder.Price1 = b_TrailStop;// Stop price
      NewOrder.Price2 = b_TradeTarget;// Trail trigger price
      NewOrder.TimeInForce = SCT_TIF_DAY;
      int Result = sc.SellEntry(NewOrder);
Question 2:
If sc.AllowMultipleEntriesInSameDirection has to be set to true, what is the best function to determine 1. The strategy is in a trade and 2. The direction of the trade? I am using sc.GetOrderByIndex(EntryID, ExistingOrder) and (ExistingOrder.BuySell == BSE_SELL / Buy) functions to determine the direction of the trade but multiple entries still exist.
[2017-09-27 18:42:03]
1. No.
2. Use this function:
Automated Trading From an Advanced Custom Study: sc.GetTradePosition
Date Time Of Last Edit: 2017-09-27 18:43:08
[2017-09-27 20:27:10]
Okay, if you were going to allow reversals and use the SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_3_OFFSETS order type what would the sc.Defaults need to be?
[2017-09-27 20:47:10]
We can only refer you to the documentation here:
Automated Trading Management
Have a look at SupportReversals.
[2017-09-27 20:52:36]
Cool and thank you!
[2017-09-27 22:18:15]
My sc.Defaults are :
sc.AllowMultipleEntriesInSameDirection = false;
sc.AllowOnlyOneTradePerBar = true;
sc.MaintainTradeStatisticsAndTradesData = true;
sc.AlertOnlyOncePerBar = true;
sc.SupportReversals = true;
c.AllowEntryWithWorkingOrders = true;
sc.CancelAllWorkingOrdersOnExit = true;
I initial launch an order and a stop when certain conditions are met. Next, if another type of conditions are met I am launching a SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_3_OFFSETS as a BuyExit or SellExit depending on the entry needed. This works great bc the Trailing Stop will launch with sc.AllowMultipleEntriesInSameDirection = false. The issue is that when a reversal condition is met. The order cancels out the reversal order if the trailing stop did not close out the initial order.
I need to have sc.AllowMultipleEntriesInSameDirection set to false bc if not my system will launch multiple entries. If I try to use sc.GetTradePosition and require the entry to launch if sc.GetTradePosition = -1 meaning it's not in a trade then my entries will not reverse bc it's in a trade when the reversing entry is launched.
If I change SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_3_OFFSETS to a BuyEntry / SellEntry the orders will not launch bc I have sc.AllowMultipleEntriesInSameDirection set to false. Any suggestions? I feel like I am running in circles.
